Bronco II Ford Bronco II
Bronco II - starter probs
Old Jan 14, 2001 | 07:02 PM
billseal's Avatar
billseal
Getting things fixed down in Belize is hard and my Bronco is no exception.
Starter has been apparently jamming accompanied by a single click sound from under the hood on turning the ignition. Then it really started playing up, starting with just the ignition turned as far as 'on', then not stopping 'starting' and then still continuing to turn the starter with the ignition turned back to off! now all is dead, no lights nothing, only the 'key in ignition buzz' thats all. Its a '81 Bronco II.
Hope someone can help.
Bill
Old Jan 14, 2001 | 08:41 PM
thelonerangerxlt's Avatar
thelonerangerxlt
Bill, sounds like the trouble is in either the starter solenoid (under the hood) or your ignition switch. I would suspect it's the switch. Try checking the connections on the solenoid first, you may get lucky and find it's something simple. Don't know how hard parts are to get in Belize, but both the solenoid and switch are used on several model Fords so hopefully you can find them. (Didn't know Ford made an 81 deuce?)
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Jan 21, 2001 | 08:17 AM
dinosaurfan's Avatar
dinosaurfan
Travis Greever
1966 - 1977 Early Broncos
Jul 10, 2016 08:29 AM
Roswell
Georgia Chapter
Feb 10, 2016 08:08 AM
TrussGod
Bronco II
Aug 26, 2009 08:37 PM
maulsmasher
1978 - 1996 Big Bronco
Mar 27, 2003 10:09 AM
nixvet
Apr 23, 2001 12:10 PM
