is this acceptable, crank ?
Old Oct 9, 2004 | 03:02 PM
f100guy's Avatar
f100guy
hello i am working on an 87 HO engine and the machine shop mic´d the crank at std. but it was on the low side of std. they ordered me some .001 bearings for it. is this acceptable, they are a good shop. and the crank was traded with mine and had a 20 dollar polishing fee.
Old Oct 9, 2004 | 05:10 PM
holland501's Avatar
holland501
I would plastigauge each journal to be sure your clearance's are within spec. Be sure there is an understanding with the machine shop that if there is a problem with clearance that you can return it. Good luck.
Old Oct 10, 2004 | 08:45 AM
kotzy's Avatar
kotzy
Sounds like a good honest shop to me. They could have ground your crank and made
more money. I've used many polished shafts, sometimes combining std and .001 undersize inserts to get the clearances I wanted, never had a problem. Trust them,
I would.
Old Oct 10, 2004 | 04:24 PM
mark a.'s Avatar
mark a.
You can mix standard bearings with .001 if it's too tight.
Old Oct 14, 2004 | 05:02 PM
f100guy's Avatar
f100guy
for some odd reason i only get certain email notifications on very few posts. i started to plastigauge today and got a very health line with no sign of taper. it measured out to be .002 of an inch in the main bearings. is this a good clearance.
Old Oct 15, 2004 | 04:34 PM
kotzy's Avatar
kotzy
That should be fine.
Old Oct 16, 2004 | 01:53 PM
f100guy's Avatar
f100guy
i checked the rod clearance and got .0015 and no taper at all, i heard this is good. is it
Old Oct 16, 2004 | 03:07 PM
kotzy's Avatar
kotzy
Very good, sounds like it will run fine just check them all and torque everything to
factory torque specs.
bjmayberry2
Aug 15, 2015 09:10 AM
GB SISSON
1947 and Older Ford Trucks
28
Mar 19, 2015 01:42 PM
Bamadawg63
Dec 4, 2013 08:43 PM
joey little
1983 - 2012 Ranger & B-Series
Mar 8, 2006 03:16 PM
f100guy
Jan 10, 2006 06:32 PM
