Bronco II Ford Bronco II
Bronco II problems...
Old Apr 12, 2001 | 11:07 PM
provoice's Avatar
provoice
My brother has an '86 Bronco II 4by with a fuel injected 6... bought it with what he thought was a timing chain problem... back-fired, blew muffler off, ran BAD... he pulled the timing chain cover and it was fine... replaced distributor cap and rotor, coil, coil wire, checked out timing, etc. Starts, but still runs awful. He says the spark appears weak but can't find a thing wrong with it!
Any ideas?
Old Apr 13, 2001 | 01:00 AM
redbronco2's Avatar
redbronco2
It might be the TFI module. When replacing the TFI module Ford recomends replacing the stator assambly too. Good luck.
Old Apr 13, 2001 | 09:42 AM
provoice's Avatar
provoice
He says the TFI checks out as okay, don't know if the test checks out the stator or not.
Old Apr 28, 2001 | 02:42 AM
redbronco2's Avatar
redbronco2
I would check that. If its good, lemme know and I'll brain storm somemore.
Old Apr 28, 2001 | 10:22 AM
provoice's Avatar
provoice
He's decided to JUNK it... let me know if anyone wants a good five-speed or a few other worthwhile parts!
Old Apr 28, 2001 | 10:38 AM
redbronco2's Avatar
redbronco2
Actually I'm in need of a few parts. I need the shift lever for on the transer case, not the one in the cab.
Old Apr 28, 2001 | 09:25 PM
cbadgerjr's Avatar
cbadgerjr
Where is the Bronco II located at? If near Chicago, there are a few parts that I can use as well.
Old Apr 29, 2001 | 12:28 AM
provoice's Avatar
provoice
Yeah... give him a call. He lives in Kalamazoo, Michigan...
616 - 345-8682 His name is Jim.
provoice's Avatar
provoice
Old Apr 29, 2001 | 09:39 AM
redbronco2's Avatar
redbronco2
Desert Dog
Bronco II
25
Jan 23, 2006 03:21 PM
biggreen4x4
Bronco II
Jun 2, 2003 02:13 PM
rfgree
Dec 31, 2002 10:34 PM
fatforty
Bronco II
Jun 22, 2002 11:12 PM
Avanti
Bronco II
Mar 16, 2002 01:20 PM
