Backfiring through the carb
Old Oct 7, 2004 | 08:50 AM
51dueller's Avatar
51dueller
My Motorcraft 2150 is backfiring through the carb. What can I do to stop this. I does it when I crank the engine. Any help is much appreciated.
Old Oct 7, 2004 | 12:21 PM
fmc400's Avatar
fmc400
MSEE
Is your choke shut before you start the motor?
Old Oct 7, 2004 | 12:55 PM
51dueller's Avatar
51dueller
The choke plate is shut when it starts but we had it held open to see if it was flooding and it still backfires through the carb. I hope it isn't a stuck valve.
Old Oct 8, 2004 | 03:00 AM
Ford_Six's Avatar
Ford_Six
Any other info, year, engine size, miles?
Old Oct 8, 2004 | 08:23 AM
Redbob's Avatar
Redbob
See, we're supposed to know that "51" has a, well, '51.
<grin>
Coupla things will cause backfires:
Much too rich a mixture (like from a stuck carb float) results in very slow-burning combustion that is still going on when the intake valve opens again, producing a backfire.
Or if the timing is much too much advanced, it might do it.
This can happen if the centrifugal advance mechanism gets stuck.
Regards,
- R
Old Oct 8, 2004 | 12:56 PM
51dueller's Avatar
51dueller
It's an '84 Mustang 302 that original had CFI but has been converted to a Motorcraft 2150. Don't know miles since I got it from a wrecker
Old Oct 9, 2004 | 02:38 AM
Ford_Six's Avatar
Ford_Six
Well, since it isn't a 51, I may be able to help you out a bit.
It sounds like the timing chain jumped a tooth. Engines from this era had a plastic rim on the cam gear that wore away after about 70k, and once that happened, there was major slop in the chain. Check your timing, even if you can only do it while cranking. If it isn't right close to 5*, then the chain may have skipped. Also, if the engine sat for a long time, it may have a stuck valve, but that wouldn't be the end of the world.
Old Oct 9, 2004 | 08:37 AM
51dueller's Avatar
51dueller
The rotor seems to move right after you start turning the engine over by hand. If it's a stuck valve would you not have to remove the head?
Old Oct 9, 2004 | 12:29 PM
51dueller's Avatar
51dueller
I got it running . The distributor timing was off and I was using the wrong firing order.
77F250CUSTEXP
Jul 8, 2011 11:47 AM
Goker73
21
Feb 3, 2011 01:10 PM
Countrywfo
Feb 1, 2011 06:44 PM
Arnold Kenyon
13
May 12, 2005 09:31 AM
GDANET
Aug 21, 2004 10:31 AM
