dimmed headlight
Old Oct 7, 2004 | 05:51 AM
MENESLIS's Avatar
MENESLIS
Question dimmed headlight
I just changed my bulbs for the headlight for the second time. First and only reason was becasue the right headlight just got so dimm that it wasnt producing any useful lighting. Shorty like about 2 week after replacing both bulb again, same thing... right headlight just dmmed out. I can understand 1 bulb blowing out but not producing enough light is beyound me. Need I mention the left is bright enough.
Old Oct 7, 2004 | 08:08 AM
scholzee's Avatar
scholzee
More than likely something wrong with the wiring harness or terminals in the connector, possibly the ground wire for the bulb. You will have to measure voltage at the bulb pins with the bulb on and see how much voltage is getting to it. Check wiring harness for any chaffing, see if one of the wires goes to ground and clean that connection. Look at the terminals in the connector for discoloration or corrosion.
Old Oct 7, 2004 | 09:19 AM
jas88's Avatar
jas88
Yeah, typically when you have one bright light and one dim light, it is a grounding problem. Changing the bulb is just jiggling the wires around and getting you a better connection, for a while. Check where the ground wire bolts to the fender.
Old Oct 7, 2004 | 04:47 PM
Yellow FX4X4 SCab's Avatar
Yellow FX4X4 SCab
90% chance it's a grounding problem... had it on several Fords... '77 Granada (I'm ashamed to admit)... '84 T-Bird... '94 Cobra....
Follow your grounding wire and check where it bolts to the body... check the connection at the headlight... and check the condition of the grounding wire.
marksp
2009 - 2014 F150
Jan 16, 2014 07:00 AM
1L243
22
Apr 7, 2013 09:42 PM
skscci
Apr 7, 2012 04:55 PM
dirtjb18
Electrical Systems/Wiring
Jan 10, 2006 08:21 PM
