Light Knock
Old Oct 5, 2004 | 03:47 PM
jmcgardner's Avatar
jmcgardner
Light Knock
I have a 1997 F250 with the 460 with 129000 on the clock. I bought the truck a few months ago and just noticed a knock under load at highway speeds. I am curious if this is could be solved with a higher octane fuel. My 89 aerostar runs without any rattling with mid grade gas, but you drop it to the cheap stuff and she rattles like mad under load. Any insights would be appreciated as I am new to this engine.
Thanks.
Old Oct 5, 2004 | 09:46 PM
madman666's Avatar
madman666
I’m sure higher octane gas would help.
But, it should run on 87 just fine, first check the timing the previous owner may have advanced the timing 2 or 3 degrees to get more power.
Just put it to what the catalyst sticker says.
Or the knock sensor may be bad, if it has one... not sure if it does.
To test that, hook up the timing light, and tap the block with a hammer near the KS, the timing should retard briefly.
Old Oct 13, 2004 | 07:58 AM
jmcgardner's Avatar
jmcgardner
Checking the Timing
What is the process to check the timing? Is this done with a timing light as well? Sorry for the ignorance.
Old Oct 25, 2004 | 11:01 PM
madman666's Avatar
madman666
Hey not a problem....I’m the only guy at our dealership that has a timing light!!!!
Ok first you must locate the SPOUT connector; it will be near the wiring on the ignition module. I think it’s on the driver’s side lower inside fender.
It’s a grey plug you pull out of a connector.
When you pull this it takes the computer out of the picture so you can set base timing.
Now take the timing gun inductive clip and put it on the NO# 1 plug wire
Hook up the + an -
Now point it at the crank damper, and timing indicator bolted to the block.
Make sure it’s at 10 degrees advanced.
If you need any more info about this please let me know.
RedRaider15
Modular V10 (6.8l)
Sep 17, 2014 10:48 PM
TimV
1983 - 2012 Ranger & B-Series
Mar 1, 2010 11:43 AM
powerstroke6ltr
16
Dec 19, 2005 09:35 PM
jmcgardner
Oct 5, 2004 04:24 PM
jpb222
16
Jun 12, 2003 09:41 PM
