Aerostar Ford Aerostar
Tranny Swap
Old Oct 5, 2004 | 11:24 AM
goldenii27's Avatar
goldenii27
Tranny Swap
Hi there.......my tranny is gone in my 1993 4.0L 2WD Ford Aerostar. My friend has a 1990 4.0L 2WD Ford Aerostar with a re-built tranny that wants to get rid off. Would anybody know if these tranmissions are the same?
My van has a newer dashboard and you switch gears on the steering wheel where as the other van (1990) you switch gears on the floor between front seats. From below the trannies look very similar except for some wiring that is little bit different. Please advise and help........
Thank YOu.
Robert
Old Oct 5, 2004 | 11:49 AM
aerocolorado's Avatar
aerocolorado
I believe the only difference that would prevent the swap would be the speedometer drive unit. If one is a digital dash and the other an analog equipped one the sending units may be different or require a swap of additional pieces. Otherwise, they are interchangeable. Transmissions are not my forte, so it would be helpful to get another opinion on this before proceeding.
Old Oct 5, 2004 | 12:15 PM
cookkd's Avatar
cookkd
I have basically the same question......I have a 90 Eddie Bauer with Digital dash that has a wrecked body....my 91 xlt with analog dash has a marginal tranny.
Will they swap?????
Old Mar 15, 2005 | 01:42 PM
goldenii27's Avatar
goldenii27
YEs, they will swap. The newer van get their speedometer reading from the axle if I remember correctly. At the front of the tranny you just have to make sure there is same amount of wires, once again if I remember correctly. Also the leaver for changing the gears needs to be replaced. It's definitly doable, it has been done on my van and it drives really nice.
Hyser
Aerostar
Sep 28, 2016 07:29 AM
Hyser
Aerostar
Feb 25, 2016 11:29 AM
BAD RONALD
Aerostar
Jul 22, 2015 11:26 AM
Aero-fan
Aerostar
Mar 18, 2008 07:23 PM
dougas
Aerostar
May 22, 2002 10:14 PM
