dim brake lights
Old Oct 2, 2004 | 01:12 AM
kayladog1's Avatar
kayladog1
dim brake lights
Brake lights are dim. Checked with meter. Only getting 8-9 volts to the brakelights. Tailights have 12V. Have 12V at brake light switch. Have tried tracing this but can't find where voltage loss would occur. Any suggetions.
Old Oct 2, 2004 | 06:47 AM
Freightrain's Avatar
Freightrain
There is a plug at the rear frame on driverside, might be crusty there??
Old Oct 2, 2004 | 06:50 AM
jowilker's Avatar
jowilker
Dirt or corrosion, is likely the culprit. Do ya have one of those combo battery brushes? Try running the cable end into the socket and giving it a few turns.
let us know
John
Old Oct 2, 2004 | 11:44 AM
4x4Subaru's Avatar
4x4Subaru
Also use the brighter bulb. Yours are probably still 1157. I can't remember the number 21??. They look the same just a bigger number.
Old Oct 3, 2004 | 01:59 PM
rebocardo's Avatar
rebocardo
DIsconnect the harness under the hood and see if you have 12v going out of the dash harness. If not, the cause might be the directional switch. Otherwise the brake connector under the hood or the wire from it is bad.
Check for a good ground at the light.
Old Oct 3, 2004 | 05:04 PM
Faithful Old Road Dog's Avatar
My vote would be the dirty, crusty, rusty light socket.
saxtonj
Jan 3, 2014 05:16 PM
02SuperPoop
Dec 29, 2013 09:54 PM
AllaboutMPG
Jul 14, 2013 08:36 AM
damon2004
Electrical Systems/Wiring
Aug 15, 2012 03:01 PM
briank
Mar 16, 2012 06:01 PM
