Bronco II Ford Bronco II
Checking codes Question!!
Old Dec 27, 2001 | 12:56 PM
nytemare1's Avatar
nytemare1
Have a 86 B2 & would like to run a code check. Stupid Question but can I & if so how do I go about it. I have seen different mentions of this around but they involve decoders & ohm? meters & such. Can I use the ignition method on my model year??
Thanks in advance people,
Eddie
Old Dec 28, 2001 | 10:46 AM
mrshorty's Avatar
mrshorty
Yes, you can. I have an '87 BII and a '92 Explorer and use an analog volt meter to read trouble codes. It's not very difficult. You'll need a manual to get the details, but one lead of the ohm meter goes to the battery, one lead to the diagnostic connector, and a jumper wire to connect two leads of the connector.
Be sure the manual you get actually describes how to hook up the leads. The Chilton manual for my Explorer tells you that it can be done, but forgets to tell you how. The Haynes manual for my BII adequately describes the hook up and test procedure. Sometimes I go to the library and get the Motor Professional Edition manual and use that to get all the details for running the tests.
After having done it once or twice, you'll wonder why anyone would pay $40-60 for someone else just to extract trouble codes from the computer.
Old Dec 28, 2001 | 05:13 PM
cbadgerjr's Avatar
cbadgerjr
SUPERDUTY_08
6.4L Power Stroke Diesel
Aug 28, 2016 08:00 AM
saltydog463
Jan 15, 2016 06:16 AM
kbf1961
Oct 17, 2015 10:05 PM
socal00
Oct 5, 2010 02:09 PM
blue96psd
Aug 6, 2006 06:51 PM
