Generator/battery light
Old Oct 1, 2004 | 08:17 AM
snipa's Avatar
snipa
My '53 was converted to 12 volt system before I bought it.
It still has a generator, but my question is when the engine is running and I come to a stop, the battery light comes on. It goes away if I pull out the choke to run the rpm a little more
Is this normal, or what needs to be done to fix it?
Thanks all
Old Oct 1, 2004 | 09:06 AM
holland501's Avatar
holland501
Don't worry, it's sorta normal on older generator systems. Put a volt meter on it and check out-put at idle. As long as it goes out when you get off idle you should have no problems unless you spend a lot of time idleing the engine. Try just adjusting the idle up a hair and see if that makes you feel any better. Good luck.
Old Oct 1, 2004 | 09:52 AM
Jag Red 54's Avatar
Jag Red 54
I've read where some guys will install a smaller pulley on the generator. This works to increase the rpms of the generator and gives you more power at idle. John
jamhh
Sep 19, 2014 10:15 AM
azcan62
Feb 13, 2013 05:48 PM
1950ford
Sep 28, 2007 01:00 AM
Daveski
20
Apr 27, 2007 09:45 PM
germanbrave
Electrical Systems/Wiring
Dec 9, 2004 10:46 AM
