Offroad & 4x4
Superunner Steering
Old Oct 1, 2004 | 07:42 AM
Chaos 95's Avatar
Chaos 95
Superunner Steering
I just got a superunner steering kit for my 95 F250. It says you must use the superlift dropped pitman arm. Does anyone know what the differance is between the superlift arm and any other one? I would hate to spend the extra money if the one (pro Comp) that I have now will work.
Old Oct 1, 2004 | 08:42 AM
fishmanndotcom's Avatar
fishmanndotcom
as long as it is dropped it doesn't matter! they are trying to get you to buy more stuff....do the 2 pitman arms look almost identical?
unless i am not understanding correctly but i believe i do!
-cutts-
Old Oct 1, 2004 | 10:24 AM
Chaos 95's Avatar
Chaos 95
thats what i figured but i dont have a superlift arm to compare with the one i have. i'm going to try it with my arm and see how it fits.
Old Oct 1, 2004 | 11:24 AM
fishmanndotcom
i am almost 100% certain it is the same thing!
-cutts-
Old Oct 3, 2004 | 12:27 AM
rlh's Avatar
rlh
Its the axle pivot brackets where stuperlift screws you in the earhole. You have to have superlift pivot brackets for the supperunner steering. You can get them from JBG for ~250.
Old Oct 3, 2004 | 10:26 AM
MustangGT221's Avatar
MustangGT221
No you don't HAVE to get the brackets....I refused to get the superlift brackets because they stink in comparison to the skyjacker brackets (the superlift kit on my other F-150 stunk in general to my new skyjacker kit)...but I still got the superrunner steering under my truck.
So I took a piece of 1/4" steel plate, welded it between the skyjacker bracket and the crossmember. Then I modified the bracket on the superlift kit, welded it to the piece of steel..and away I go.
The pitman arm doesn't matter as long as the joint at the bottom of the arm is at a proper angle.
I had the superlift pitman arm and the skyjacker pitman arm side by side and they were similar enough I just used the skyjacker one.
Old Oct 3, 2004 | 10:33 AM
rlh's Avatar
rlh
Slightly off topic, what is the differences in the F250 supperunner steering vs. the Bronco/F150 one? In other words would the F250 steering work on a Bronco?
Old Oct 3, 2004 | 10:37 AM
fordsrgrt's Avatar
fordsrgrt
i agree with you on that mustangGT i have the skyjacker brackets on mine and a friend gave me his old superrunner system i just drilled the 4 holes and mounted the idler arm no problems also i have a pro comp pitman arm on it from my first lift
Old Oct 3, 2004 | 06:39 PM
MustangGT221
I believe it's the same steering...call up superlift (superlift.com) and ask
Old Oct 4, 2004 | 11:35 AM
rlh's Avatar
rlh
I asked them and they said NO. I was looking at a new runner for a pre85 F250 because they required mounting the idler bracket to the crossmember rather than the pivot bracket. I thought it may be "heavier" but would work since the early 80 F250s had leaf sprung d44 ttb setups. I can get it new for $259.
Edit: I'm considering getting it and making it work. I've got to do something about that y setup. But that is approaching the cost of a D44 HD for a SAS.
Sorry about the thread hijack.
bchunter
Offroad & 4x4
Dec 14, 2006 01:07 PM
fordman300
Offroad & 4x4
Apr 10, 2004 05:19 AM
rabidranger
13
Oct 31, 2002 08:33 PM
mic
Apr 18, 2002 05:35 PM
slik
Dec 27, 1999 07:34 AM
