6.0 air filter alignment problem
Old Sep 30, 2004 | 07:24 PM
curlee's Avatar
curlee
Exclamation 6.0 air filter alignment problem
I previously made this post but it does not look like it showed up any where so I will try it again.
I have a 2004 xlt with a 6.0 power stroke and noticed that the rear section of the air filter assembly does not seat and seal properly on the center housing.When looking at it from the front of the engine, the edge towards the passenger side has a larger gap than the other side.The front section mates up tightly with a consistant size gap all of the way around the sealing area. When I took the sections apart I did in fact notice dust and dirt in the intake tube going to the turbo. For the time being I added some duct tape around the area in question to seal it. I have found two others at this time that have the same problem. I contacted the dealer and so far they have not taken this seriously.The dirt that enters this area will definately compromise the turbo and the life of the engine. Any help will be greatly appreciated.
Thanks Curlee
Old Sep 30, 2004 | 08:20 PM
SBV45's Avatar
SBV45
Here is a bulletin from Ford:
6.0 Air Cleaner Housing Appears Warped/Misaligned:
The appearance of a misaligned sealing surface between the air cleaner and mass air flow sensor is due to the design of the air induction system and the positioning of the clamps. The air cleaner should be sealed providing the gap is not greater than 16mm (5/8"). If the gap is greater than these measurments, attempt to reseat the air cleaner to the mass air flow sensor. If the gap is still too wide, replace the air filter element only.
Broadcast Message 0925, 1581
Loosen the intake tubes between the filter and the turbo. Reseat the connection between the MAF and filter.
Old Sep 30, 2004 | 09:02 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WELCOME to the site, please read the Guidelines… Check out the list of forums and make sure you read the headings and Read First: notices in each forum.
Be sure to check out the 6.0 Bible
http://dan.prxy.org/Truck/6L_bible_html/html/TOC.html
………and in the upper right hand corner of your screen check this out PARTS SHOP for all your truck needs
Enjoy FTE
Old Oct 3, 2004 | 09:39 AM
Lnd Svyr's Avatar
Lnd Svyr
Mine appears exactly as you describe. Better keep an eye on it I guess.
ktownf350
Dec 1, 2014 03:36 AM
Under Pressure
Mar 21, 2014 01:59 PM
Bruin008
Feb 25, 2013 10:29 PM
milfpig115
Oct 1, 2010 05:40 PM
ernesteugene
211
May 24, 2009 01:38 PM
