Air intake distortion
Old Oct 1, 2010 | 03:51 PM
milfpig115's Avatar
milfpig115
I have a 2006 F-250 with 65k and have noticed that the left side (when looking at it from in front of the truck) of the air filter and the plastic housing behind it do not meet with a tight seal. It appears that the plastic piece containing the MAF sensor and filter housing do not match up tightly. There is a gap approximately 1/4in near the bottom and I am concerned about dusting the turbo because of gunk being sucked up.
It almost appears that the plastic with the MAF sensor has warped from heat and curled back a little bit preventing a proper seal. It also appears to be a bad design in that there are no clamps holding the seal on that side of the filter. I've read on here that someone has had the same issue and my brothers 2005 6.0 has the same gap and warpage, just not as much.
Should I just duct tape the gap? I know that the filter is seated properly and all 4 clamps are in place and operating as designed. I know aftermarket intakes are discouraged but if this is a common issue then what good is a great air filter but crappy design allowing unfiltered air into the turbo? Please help.
Old Oct 1, 2010 | 03:54 PM
gearloose1's Avatar
gearloose1
1. Post some photos.
2. I would be real concerned about the possibility of heat damage.
Lets investigate that.
Interim kludge -- duct tape.
Old Oct 1, 2010 | 04:16 PM
dchamberlain's Avatar
dchamberlain
There are tabs on the bottom of the filter housing that should go into slots in the bottom of the filter body. Are those tabs engaged properly? If not, the filter housing cannot properly seat against and seal against the filter.
Old Oct 1, 2010 | 04:57 PM
milfpig115's Avatar
milfpig115
Yes the tabs are engaged at the bottom but upon closer inspection I found that the MAF tube is up against the engine lift hook preventing proper seating. This is where the engine would be lifted with a cheery picker. The engine is a reman motor that FoMoCo put in about 35,000 miles ago under warranty. Should I cut off the hook point or what?
Old Oct 1, 2010 | 05:00 PM
Maxium4x4's Avatar
Maxium4x4
Remove the assembly and see if you can influence the lift hook out of the way, probably bent.
Changing your air filter video
dchamberlain
That's weird. Is there any way you can get some pictures. If anything, put them in a Photobucket account and post links to them.
My truck doesn't have a lift hook anywhere near the MAF sensor. But I have an '04 and there may be differences.
Maybe the hook unbolts. I don't know though.
Old Oct 1, 2010 | 05:05 PM
amgpro2's Avatar
amgpro2
My 05 did the same. Was not sealing right. I wonder if they had a bad batch of plastic,abs or what ever the housing is made out off? Actually had a little dusting from the OEM. Lucky I caught it early. I use a little grease around seal and duct tape until i bought an S&B.
Old Oct 1, 2010 | 05:31 PM
milfpig115's Avatar
milfpig115
Thanks guys I will give it a try. After watching the video I guess I was fighting removal of the filter assembly way too much. It seemed time consuming but way easier then trying to fit the filter element down in and realigning everything up in place.
Old Oct 1, 2010 | 05:40 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Wish I had seen this video a while ago. Thanks for sharing Maxium.
SpartanDieselTech
Apr 10, 2014 09:41 PM
59203shop
Oct 9, 2013 11:26 AM
old broke prospector
Jul 2, 2013 10:50 PM
d445
2009 - 2014 F150
27
Feb 3, 2010 10:30 AM
curlee
Oct 3, 2004 09:39 AM
