Any contractors out there? -Partition wall question.
I'm needing to put up a partition wall in my basement. The problem is that the steel I beam and ductwork runs right across where I need to put the wall. My wall will be perpindicular to the ducts. The problem is that there will be a span of wall that is about 6 feet long that won't be attached to the ceiling joists. Obviously it's not load bearing, so I'm not worrying about the strength, I just don't want the wall to have any give when it gets bumped into. Anyone have any suggestions?
Thanks in advance.
Matt
Thanks in advance.
Matt
I think I see it now. The 6 ft you're talking about is the part beneath the ductwork.
Put in a header between the studs on either side of the ductwork, and run your studs up to it, just as you run the rest of the studs to the top header (which, if I'm picturing this right, will be running parallel to the joists and parallel to the I-beam. Will the header be attached to the bottom of a joist, or to nailers between the joists?
Lots of people put in nailers flat, 'cause it's easy and somehow seems right. It will be a lot easier to nail a header to a vertical nailer, though, and the wall (as well as the floor above) will be firmer.
If you're screwing on the header, it will be just as easy either way, but vertical nailers will still result in firmer construction.
first off i know i'm gonna get crap but my g-pa owns a construction company here(brag brag brag, lol) but bolt it to the concrete floor. that'll give you a lot of strength. use 2x4's and figure where you want your wall to be and then drill into the 2x4 until you hit concrete then go about a 1/4" to mark the holes. the put in the fasteners and bolt it down. use simpson strong ties if you want strength for the top. don't toenail anything. it makes it weak. i'll do it for you for a measly $250 and supplies and hotel and flight and car rental. lol. j/k. anyways hope this helps. i think i know what your doing. Good luck!!!!!
Drive It Like You Stole It!!!
fred_79f250
08-26-2007 09:29 PM
