Parking Brake Light
Old Sep 28, 2004 | 08:59 PM
pbuehning's Avatar
pbuehning
Parking Brake Light
I've got a 98 EB w/ 5.4L, Air Ride and 72,000 and I love it. I had the parking brake adjusted this past summer, but now the indicator light doesn't come on when I set the brake. Help please!
Old Sep 28, 2004 | 10:48 PM
MisterCMK's Avatar
MisterCMK
It sounds like the bulb could be bruned out in the instrument cluster. First thing however, check and make sure that the switch is working correctly.
Old Sep 29, 2004 | 06:44 PM
pbuehning's Avatar
pbuehning
Where is the switch
Any idea where the switch is and if thats OK how do I get at the bulb.
Old Oct 15, 2004 | 04:30 PM
blwilli's Avatar
blwilli
does the brake light come on when you first start the vehicle?
Old Oct 16, 2004 | 07:05 AM
pbuehning's Avatar
pbuehning
blwilli - just checked, the brake light does come on when 1st started and then goes off; even thought the parking brake is set. It used to stay on, that's why I thought it may be out of adjustment. I did have the parking brake adjusted awhile ago (still working) and the light came on after the brke adjustment.
Old Oct 16, 2004 | 07:18 AM
blwilli's Avatar
blwilli
ok, good...then you know that the bulb isn't burned out...step one done...I don't know how to adjust it, but suppposedly there IS an adjustment...my problem was somewhat opposit of yours. my parking brake no longer works (one of the things I didn't repair when I did a frame off salvage of this Expy) because, well, I never use them, and they all seem to eventually bind up. Anyway, my pedal would always fall to the floor...leaving the light on all the time. Should have tried the adjustment...but I just cable tied it up instead. (gotta love that ol' Southern Engineering!).
Old Oct 16, 2004 | 10:13 AM
pbuehning's Avatar
pbuehning
Does anyone know where the adjustment for the light activation is?
Please help!
Jon.G
Electrical Systems/Wiring
Feb 20, 2015 04:55 PM
Trevor.801
Mar 12, 2014 03:44 PM
tbean
May 9, 2013 01:31 PM
connork
Mar 24, 2013 06:52 AM
Pete in Maine
Aug 21, 2008 12:22 AM
