dashboard brake light
Old Aug 18, 2008 | 10:28 AM
Pete in Maine's Avatar
Pete in Maine
My parking brake light comes on intermittently. The parking brake is plainly off. I also have intermittent brake trouble (hard pushing the pedal and sluggish response).
Does the parking brake light also come on to warn of brake trouble or is the light just connected to the parking brake (if so, any thoughts on what's causing it to light up).
On the brake trouble, any thoughts? What additional info would make the diagnosis easier?
I have a '96 4x4 F250 Ex-cab.
THanks in advance for your thoughts.
Old Aug 18, 2008 | 10:39 AM
madpogue's Avatar
madpogue
YES. This light is PRIMARILY a brake hydraulic FAILURE WARNING light. Check the brake fluid, and look for external leaks along the brake lines, and at the calipers and wheel cylinders. A common failure point with these vehicles is the line that goes from the proportioning valve, along the inside left frame rail, to the rear brakes. It rusts to the point that it looks like a pretzel stick, and then rusts through.
If it's low on brake fluid, DON'T just fill it up and be on your way. That fluid went somewhere. Some of it has gone into the front brake pistons, if the front pads are extremely worn. But that shouldn't be enough to make the light go on. Most likely you have an external leak to find.
The fact that it lights up with the parking brake is its secondary function. Forgive me if this sounds harsh, but every driver should know that the RED light on the dash that says BRAKE is primarily to warn you of hydraulic failure, and this applies to virtually every car/truck out there. IMHO, it's pretty stupid that, in most cases, they use the same light as the callout for the parking brake, because (and I've seen this all too many times on another car forum I visit) it makes a lot of people think the parking brake indicator is the only function of this light.
Old Aug 18, 2008 | 10:40 AM
Cuda_jim's Avatar
Cuda_jim
Vacuum pump going bad? Check it for leaks.
Is the HVAC stuck on defrost. It's vacuum operated and defaults to defrost under low/no vacuum.
Old Aug 18, 2008 | 04:20 PM
rungunner's Avatar
rungunner
Brake Light on dash
Pete in Maine,
I have a 97 f-350 and have the same problem for a couple of months now. I have had all the brakes done and they are perfect. I have changed both switches , one on the brake pedal and one on the emergency brake. I have replaced the wheel cylinders on the rear because one of them looked like it was leaking. I have made sure the master cylinder was full of fluid and the float in there was not stuck in the down position. I have changed the ABS senson on the rear differential. The vacumm on my truck is ok. So mine could be some short in the wiring somewhere I suspect. I don't know but the light is driving me nuts. Maybe you will have better luck finding the problem and if you do please let me know ok.
Old Aug 18, 2008 | 05:17 PM
cchildress's Avatar
cchildress
Wow I guess I should have read down the posts a little befor I posted my problem. I have the same problem!!
Old Aug 18, 2008 | 05:39 PM
Cuda_jim's Avatar
Cuda_jim
Originally Posted by rungunner
Pete in Maine,
Have you checked the switch on the parking brake lever? It's about the only thing left.
Old Aug 18, 2008 | 09:01 PM
Hussler's Avatar
Hussler
Did not believe you but I looked it up and there is a Low Vacuum switch tied into the brake warning indicator ...
Pete in Maine,
There is a low vacuum warning switch located behind the battery, left side of engine compt, of course .. nothing is ever easy to get to. It is solid state device with three wire plug, I'm guessing cause never been down that deep. Looks to me like if you unplugged it for a test and the problem goes away it is either the solid state switch or maybe the actual vacuum to the sensor. Crushes hose maybe .... ,,, best guess.
Old Aug 19, 2008 | 10:32 AM
Pete in Maine
Thanks guys. I'll have to get into the brakes as soon as I can. Nearly thirty years of driving and I never learned that the brake light warns of hydrolic trouble (or, until I found this site, that you can rap on a starter to make it work). If only reparing the brakes was going to be as easy as replacing the starter . . .
Old Aug 20, 2008 | 11:46 AM
madpogue's Avatar
madpogue
So there's a THIRD separate function tied to that light. Oh, great! Take a life-or-death warning light that already has one ambiguous extra meaning, and add ANOTHER one! And this explains why the BRAKE light stays on even when you release the parking brake, until you start the engine (no vacuum).
Yeah, I know, if you leave the p-brake on it's bad for the brakes. If you have no vacuum boost, it's hard to brake. But you usually still have something. With a hydraulic failure, depending on what has failed, you may have some brake function, but you may well have NONE. It's usually a much more dire thing than losing power boost, or dragging the p-brake. They shoulda made it mandatory years ago, that whatever other warning lights / functions they combine anywhere else, the hydraulic failure warning must be its own separate light. It should be twice as big as any other dash light. It should light up the whole cab. It should be visible from planes flying over. It should play the Star Trek red alert soundtrack. It should call your grandmother in the middle of the night and warn her.
Oops, did that all come out out-loud?
Old Aug 20, 2008 | 01:07 PM
Cuda_jim's Avatar
Cuda_jim
All the brake light warning light info is in your OWNERS MANUAL
here's a quote:
The red warning light for the brakes can show three things — that either the parking brake is not fully released, that the brake fluid level is low in the master cylinder reservoir or the vacuum pressure is low on diesel engine vehicles. If the fluid level is low, the brake system should be checked by a qualified service technician.
This light comes on when you turn the ignition key to START to verify that the indicator bulb is working. If the light stays on or comes on after you have released the parking brake fully, have the hydraulic brake system serviced.
Old Aug 21, 2008 | 12:22 AM
cchildress's Avatar
cchildress
Like I said I had the same problem I just put a new vacuum pump on and now no light a nice smooth pedal and she comes to a nice stooooop!!!!!!
Chris71
Large Truck
Mar 18, 2015 06:00 PM
90turbo1
Jan 7, 2015 07:17 AM
blank
Jan 2, 2015 03:21 PM
LFDavidson
Jan 28, 2014 05:54 PM
wagonerkl
Jan 12, 2014 03:26 AM
