Parking brake light is on???
Old Mar 9, 2014 | 01:42 AM
Trevor.801's Avatar
Trevor.801
So my 2000 Ex started showing the parking brake light as if the parking brake was on...however it is not. Anyone run into this? How, or what do I need to do to fix it?
Thanks,
Trevor
Old Mar 9, 2014 | 08:37 AM
Tom's Avatar
Tom
Check your brake fluid!
Old Mar 9, 2014 | 09:58 AM
Misky6.0's Avatar
Misky6.0
Perhaps the e-brake switch could also be not contacting pedal, thus vehicle "thinks" ebrake pedal is pushed
Sent from my Sprint PC36100 using IB AutoGroup
Old Mar 9, 2014 | 10:25 AM
Tom's Avatar
Tom
I'll say again:
CHECK YOUR BRAKE FLUID.
From the 2000 Excursion owner's guide:
Old Mar 9, 2014 | 10:40 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
The rubber stopper on your brake pedal arm can pop out and that leaves a hole that the switch fits nicely through. But like Tom said.... check you fluid heh heh.
Old Mar 9, 2014 | 02:58 PM
Stewart_H's Avatar
Stewart_H
Your fluid is fine, check the sensor.
Check your fluid too.
Stewart
Old Mar 9, 2014 | 03:57 PM
EXv10's Avatar
EXv10
Give the e brake assembly a close look.
Old Mar 9, 2014 | 05:38 PM
wpnaes's Avatar
wpnaes
Does it go off when you 'flick' the brake release lever?
Old Mar 9, 2014 | 07:25 PM
Trevor.801's Avatar
Trevor.801
Checked the fluid...Little low, but nothing bad. Topped off. Thanks for the other options, I shall look into those in the next couple days.
No it does go off if I flick the lever
Thanks!
Old Mar 9, 2014 | 08:04 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Check out the rubber stopper, it gets smashed up and doesn't press the switch. you can also unplug the connector at the switch to see if the light goes out.
Old Mar 9, 2014 | 08:47 PM
wpnaes's Avatar
wpnaes
I think your return e-brake spring is getting weak and won't allow the rubber bumper to push in (engage) the off switch. With you hand engaging the brake release, work the e-brake pedal up and down one inch from off (all the way up). Does the pedal return tight up against the switch on it's own? See pic.
Old Mar 11, 2014 | 09:57 AM
Trevor.801's Avatar
Trevor.801
Ok...I checked all of the recommendations you guys had and it worked. Not sure which item it was, but it was one of them.
Thanks again for all the help!
Trevor
Old Mar 11, 2014 | 11:49 AM
wpnaes's Avatar
wpnaes
D'oh Trevor, you know the guy with the correct answer gets a years free supporter membership to FTE!
Old Mar 11, 2014 | 12:15 PM
Trevor.801's Avatar
Trevor.801
Ummm...just split that up between all of you. Haha.
Old Mar 11, 2014 | 02:36 PM
EXv10's Avatar
EXv10
That would be me...........
