Bronco II Ford Bronco II
wet floor
Old May 21, 2004 | 08:11 PM
  #31
philrm1's Avatar
philrm1
ALso check the drip rail over the doors. I had a leak that started with a windshield replacement, turns out the rails had bondo cracks and the leak was coming from there. Re-bondoed and the leak is gone.
Old May 30, 2004 | 02:33 PM
  #32
jtwoodbury's Avatar
jtwoodbury
wet floor
I have been trying to chase a leak for almost a year now in my '95 Bronco. Water pools just inside door sill on both driver and passenger sides after rain. I have had windshield resealed/replaced. When that didn't work, I went to a bodyshop, and they sealed up rain gutters (the filler in them was cracked). I still get water.
Is there an easy way to get the cowl off the truck? I have a feeling the water is getting in through there, as other people have described on this thread.
Or is there something else I should do?
Old Jul 25, 2004 | 08:41 AM
  #33
jclopezv's Avatar
jclopezv
Lightbulb
I got the same problem last year. Here is the fix that worked for me!
https://www.ford-trucks.com/forums/s...light=jclopezv
Old Jul 28, 2004 | 12:24 AM
  #34
'87BroncoII's Avatar
'87BroncoII
a quick fix that would work way good would be like that do it yourself spray in bed linear like rhino liner instead of bondo because bondo youd have to primer or else the water might mess it up and youd have to do it twice or if the hole is to big for a spray in then do it right and fabricate a patch for it
