Tuner- ping.
Old Sep 27, 2004 | 09:55 AM
alarsso4's Avatar
alarsso4
Tuner- ping.
For the history of this subject, I refer to some of my earlier posts. I talked dirctly to Superchips and their conclusion was to use a colder t-stat and re-flash the computer.What about to use colder plugs?
Old Sep 27, 2004 | 10:06 AM
ssn randy's Avatar
ssn randy
does it do it when stock program loaded?
Old Sep 27, 2004 | 10:09 AM
alarsso4's Avatar
alarsso4
No, but I can't use the tuner in the tow or perf. mode.
Old Sep 27, 2004 | 10:11 AM
ssn randy's Avatar
ssn randy
did you check you base timing at 10 degrees BTDC? I think I would check that. i your timing is off the tuner is adding more. does tow and performance ping also?
Old Sep 27, 2004 | 10:38 AM
alarsso4's Avatar
alarsso4
Base timing is 10 deg BTC. It pings in both tow and perf.mode, not immidiately but after some miles of driving.
Old Sep 27, 2004 | 10:47 AM
ssn randy's Avatar
ssn randy
use no less than 180 degree t-stat. good gas? how many miles?
Old Sep 27, 2004 | 11:45 PM
alarsso4's Avatar
alarsso4
The truck has only 30 K miles and is in very good kondition. I use 95 oct gas and I have never heard anyone got bad quality here in Sweden.I'll probably stay with stock t-stat and skip the tuner, but I miss the added torque of it.Sorry, this post was ment for the computer/chip section.
baker1983
30
Jun 3, 2012 01:16 AM
4Lance
Oct 2, 2009 01:36 PM
devilsword
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 23, 2005 10:04 PM
bryyce62
Dec 21, 2005 03:44 PM
86'f250
Nov 25, 2005 04:39 PM
