Bronco II Ford Bronco II
how to test CV joints
Old Jun 29, 2002 | 09:38 AM
mrshorty's Avatar
mrshorty
I have a popping soind on take off in my '87 BII. I think it is probably the CV joints on the rear driveshaft. Anyone know of a good way to positively test the CV joints?
Old Jul 1, 2002 | 01:12 AM
Mauser8mm's Avatar
Mauser8mm
First off you don't have any CV joints in your rear axel because its a solid axle. It could be your wheel bering's our a u-joint going out but im not exacly sure.
Old Jul 1, 2002 | 12:04 PM
mrshorty's Avatar
mrshorty
The CV joints are on the rear driveshaft (From the transfer case to the differential). And, in case anyone is wondering, they are CV joints and not the usual U-joints that one finds on the driveline.
Old Jul 2, 2002 | 05:07 PM
joe btrucks's Avatar
joe btrucks
Hello,
with the driveshaft removed try with you hands to move the CV joint like this: with one hand move foward the CV part that attach to t-case and with the other hand move in the opposite side the driveshaft side of the CV joint. I don´t know if i are explain it well, the CV should be with no play or movement.
i hope this help!
Old Jul 2, 2002 | 08:01 PM
rebocardo's Avatar
rebocardo
loudfords
Sep 27, 2005 01:50 PM
cleevesj
1997 - 2003 F150
Jun 24, 2005 03:05 PM
bigblueexpy
Mar 4, 2005 09:17 PM
aerocolorado
Aerostar
15
Nov 22, 2004 01:24 PM
kburch
Bronco II
Nov 8, 2001 07:15 PM
