red hot glass-pac
Old Sep 24, 2004 | 02:56 PM
thecowboy's Avatar
thecowboy
red hot glass-pac
has anyone put a red hot glass pac on a 300. with no cat how loud do you think it will be?
thanks
Old Sep 24, 2004 | 04:15 PM
voodoosurfer's Avatar
voodoosurfer
pretty loud, and it will sound like a ricer once up in the rpm's alot of people refer to the sound as a loud wet fart. I tried dual glas paks and it wasnt pretty. but it depends on your tastes. good luck.oh mine were also dumping directly off of the headers. so if your running full exhaust pipe to the rear, it may sound ok.
Old Sep 24, 2004 | 04:36 PM
thecowboy's Avatar
thecowboy
thanks will reconcider it.
Old Sep 24, 2004 | 07:54 PM
bigredbeast's Avatar
bigredbeast
i have duals on my 300 and they sound decent but once in to the high rpm range they do get a little foreign sounding, but hey i needed better flow for my engine, but youll have to keep a check on the exhaust flanges they tend to work loose. all in all you have to take the good with the bad.
Old Sep 24, 2004 | 10:44 PM
Phrogman46's Avatar
Phrogman46
They work loose if you dont re-tq them after a couple 100 miles. All exhaust parts need to be re-tq after the heat and cool a couple times.
Old Sep 25, 2004 | 11:33 AM
4.9LFord's Avatar
4.9LFord
I cut off my second cat and stuck a flowtech purple hornie glass-pack on it and it sounds pretty good, not as loud as my buddys 5.9L dodge, but its deep and not ricey.
Old Sep 26, 2004 | 01:20 PM
thecowboy's Avatar
thecowboy
how did you exit the truck? i'm wanting no cat and a glass pac turnd down right after the cab ends.
Old Sep 26, 2004 | 04:28 PM
4.9LFord's Avatar
4.9LFord
i have a 2.5in turndown coming right off the glass-pak right before the rear axle.
Old Sep 26, 2004 | 08:59 PM
thecowboy's Avatar
thecowboy
thanks that what im thinking too. its not so loud its shaking things in the truck is it?
Old Sep 27, 2004 | 02:03 PM
nastruk95's Avatar
nastruk95
isn't it true that too much exhaust flow can cause the valves to burn out prematurely?
Old Sep 29, 2004 | 02:42 PM
Jaster's Avatar
Jaster
Yeah, because engines often run a bit lean after putting on a better flowing exhaust. If you set the mix correctly it should be fine
Old Oct 2, 2004 | 09:44 AM
mogunn34's Avatar
mogunn34
I just out a Glass pack on my 300 And I cut off both cats and ran a 2.5 with a turn down right after the cab. It did put new life into my '86. It sounds good to. At hwy speeds she just purrs. At city driving she rumbles on the down shift.I figure for the fourteen bucks I spent I'm happy.I even had some friends fooled they thought I put a V8 in.
dantsg
Modular V8 (4.6L, 5.4L)
Oct 20, 2008 07:40 AM
badass_f-150
Exhaust Systems
Feb 16, 2005 10:27 PM
ejfitco
Exhaust Systems
Feb 16, 2005 12:11 PM
texastwo
Sep 12, 2004 02:04 PM
pilot815
1978 - 1996 Big Bronco
Aug 3, 2004 09:30 AM
