Ingition Switch Replacement Help
Old Sep 23, 2004 | 07:48 AM
Jon-VH's Avatar
Jon-VH
Has any one replaced their Ingition switch on a '91-'01 Explorer?
My 93 is suddenly very slopy & have a hard time removing the key at times.
Had the same problem on my '93 SHO but that's been sold. I tried searching for this on this forum but found nothing.
How hard is it to replace? On my 57 Chevy it's a matter of putting in the key & pushing a spring loaded pin through a hole to get it pop out.
Also I have a factory alarm, does this have any effect?
Thanks in advance,
Jon
Old Sep 23, 2004 | 10:39 AM
Dialtone's Avatar
Dialtone
Fairly easy job.
1. Remove plastic column shroud and steering wheel.
2. Insert key, turn to run position (battery disconnected of course)
3. Locate cylinder release pin, push it in, pull key and cylinder out from switch. (It helps to have the new cylinder handy, place it in relation to old to help locate the release pin hole. I used a long blade, slim screwdriver but a coat hanger would probably work just as well)
4. Insert key in new cylinder, turn to run position, depess release pin, slide new cylinder into switch, turn key off.
5. Re-assemble steering wheel and shroud.
I took my cyl to a locksmith and had it re-keyed to the old key so it would still be compatible with other locks. Cost me around $25 for the re-key job.
Dialtone
Old Sep 23, 2004 | 12:10 PM
Jon-VH's Avatar
Jon-VH
Great thanks so much!
ItsAFord55
Mar 24, 2011 03:24 AM
sitdog84
Jan 18, 2011 09:51 PM
Bowhica
1997 - 2003 F150
Jan 13, 2011 07:38 AM
vol1966
May 16, 2010 11:40 AM
Mach73
Jul 11, 2004 05:08 PM
