Ok, I'm having a few problems with my 67 F100 again. The ingition switch fell apart and I put a newer one in from a 72 F100, it starts but now my brake light switch wont work. Is there a way to get the ignition key switch out of the starting switch?? The brakelight switch has power to it and shuts it off but no brake lights. Next issue is that I replaced the steering column and had to rewire that nightmare. Prior to this most of the wires were cut and had no t/s lights or hazards. Hooked it all up and front maker lights and hazzards in dash come on when started but do not blink. ??? Any help would be great!!
The 67 ignition switch has 4 spades and a post in the middle. The one I put in has 6 spades but only used 5. Also the 67 did not have the acc feture where the newer on does.
What I was asking about the switch, Is does the key lock cylinder come out of the switch so my keys will match??
break lights and turn signals are in the wires coming from the steering column just needing to check them wires and the hazards and brake lights and tail lights and signals
