Does pipe diamater matter??
Old Sep 22, 2004 | 09:30 PM
MidTn's Avatar
MidTn
I have a 5.4L 03 F150. I just had a dynomax super turbo SI/DO installed. The guy used 2" pipes out the rear. He said that this would give more torque over the 2.5" pipes. Is this right or should I have 2.5" pipes installed.
Also do I need and type of X pipe?
Thanks
Old Sep 22, 2004 | 10:07 PM
MatthewC's Avatar
MatthewC
He was talking about the better backpressure the 2" would give versus the 2.5". Contrary to popular belief, some backpressure is good. Im guessing that your engine is stock, so large diameter pipes arent needed. The question is what is the diameter the pipe in front of the muffler. Im betting that its about 2.5" which is fine. The pipes exiting from the muffler doesnt have any real bearing on performance.
-Matt
Old Sep 23, 2004 | 09:44 AM
NascarNut's Avatar
NascarNut
No, backpressure is not good. Exhaust velocity is. Many people get backpressure and exhaust velocity mixed up.
Backpressure is a restriction and that is what you are trying to eliminate when you put on a free flowing exhaust system. Stuff a potato into your exhaust tip and see how well it runs. Now, with that said, 2'' pipe sounds too small. I'm not that familiar with the Mod motors but 2 1/4'' would probably do well.
check out this thread-
https://www.ford-trucks.com/forums/s...essure+falcon+
Old Sep 23, 2004 | 09:50 AM
NascarNut's Avatar
NascarNut
With a larger pipe you will not lose torque but it will be moved up the RPM band. But, like I said, 2" pipe sounds a little small.
Thanks
No, you only need a crossover if you have true duals.
Old Sep 24, 2004 | 08:51 PM
kens64's Avatar
kens64
I agree, 2" does sound too small.
70-360fe
May 4, 2012 12:37 AM
Psyclopse
Feb 4, 2012 02:35 PM
nuthinbutfords
Modular V10 (6.8l)
Jul 19, 2010 12:55 PM
fballer985
Exhaust Systems
Mar 3, 2008 05:25 PM
TexasGuy001
Feb 22, 2008 01:01 PM
