Bronco II Ford Bronco II
Fast Idle
Old Oct 19, 2002 | 10:39 AM
VetteGuy's Avatar
VetteGuy
Fast Idle
Hi all,
I recently purchased an 88 Bronco II 4x4 to use as a winter driver and backup transportation to allow me to get into some more complicated projects on my vette.
I have had the Bronco less than a week and can already tell I am going to enjoy it. The body is fairly solid on it at 130k and V6 and 5 speed trans seem to do ok, although I do miss the V8 rumble.
The only thing that really bugs me about it is that it idles well above 1400 rpm. I picked up a Haynes manual for the truck and didnt seem to have any luck finding anything regarding idle speed and fuel injection.
If any of you wouldnt mind making a couple of suggestions, I would definately appreciate it.
Ron
Old Oct 19, 2002 | 08:24 PM
AbadDriver's Avatar
AbadDriver
Post Fast Idle
[updated:LAST EDITED ON 19-Oct-02 AT 09:24 PM (EST)]well my '86 had that same problem just that mine ideled around 1900 rpm. The big thing on mine was when the plenum was removed part of the old gasket was still there, so it had a good sized vacuum leak. I also replaced my TPS and cleaned the throttle body. Now mine runs at about 800-900 rpm.
Tim
Old Oct 19, 2002 | 10:57 PM
VetteGuy's Avatar
VetteGuy
Fast Idle
Thanks Tim,
I did some looking and found a screw that looked like it controled the idle speed and backed it down. It idles at about 900 now, but kind of rough. I bought some plugs, leads, cap and rotor today, so I will try to give it a little tune up tomorrow. My investigation also revealed a vacuum hose unplugged from somewhere with a screw stuck in the end. I am guessing that may have something to do with it also.
The guy I bought it from said he had the heads rebuilt on it about a year ago, so I haven't ruled out your suggestion yet either. It may be possible that the top end wasn't put back together correctly. I still need to do some digging around in there.
Thanks for your help,
Ron
Old Oct 20, 2002 | 10:25 AM
motorbreath's Avatar
motorbreath
Fast Idle
mine starts out at a fast idle around 1500 but then drops off
after warming up too the normal 800-900. i took it too ford to se if their was a problem and they ran all the tests and said nothing was wrong and that the fast idle like i have works like a choke on a carb.
86 b2 xlt 2.9 efi v6
Old Oct 20, 2002 | 10:09 PM
VetteGuy's Avatar
VetteGuy
Fast Idle
Motorbreath,
Thanks for the input, that was my thought also, but even after it warms up (20 mins on the highway) it didn't drop down at all. I was able to idle it down some with a screw on the throttle linkage, but now it seems to idle like crap. I have a tune up kit for it that I had hoped to get to today, but it seems the rest of the world exists to keep me out of the garage when I most want to be there. I will drive it to work this week and get to know it a little better then put the plugs/leads/rotor/cap on next weekend.
By the way, any tips on that last plug on the passenger side head? Looks like pretty hairy with that AC box back there.
Thanks,
Ron
Old Oct 23, 2002 | 02:23 PM
bronco222's Avatar
bronco222
Fast Idle
i been fightin the same crap all week,finally gave up on trying to get a smooth idle out the 2.8 in my 84 b2.i did however get it ta start an run like a raped ape and set the fast idle etc etc but man this is pissing me off to no end.i too did the valve seals so i am thinking maybe theyre needing to be regapped on the lash again.
Old Nov 3, 2002 | 07:35 PM
rebocardo's Avatar
rebocardo
Fast Idle
Doing spark plugs on a BII (or Aerostar) is as easy as pie if you do most of them through the wheel well opening. Jack up the vehicle until the wheel droops down and you have easy access to the plug. If you have a body lift kit you can reach in and remove the plug wire, no sweat!
Old Nov 3, 2002 | 07:38 PM
rebocardo's Avatar
rebocardo
Fast Idle
Ron Earp
Modular V10 (6.8l)
Feb 25, 2012 08:08 PM
99350Ron
Feb 3, 2010 04:04 PM
ron4u
1997 - 2003 F150
Apr 24, 2004 02:11 AM
Ron G.
Dec 6, 1999 05:48 PM
