1971 351 windsor-anygood
Old Sep 21, 2004 | 09:04 PM
butchf250's Avatar
butchf250
ok guys need some help i dont no anything about this engine i only run 351m-and 400--so here gos i found a 71 351w 4-barrel says it runs very good havent went to look or here it run yet how much hp-torque it has and would this make a good engine for a 1977 f-250 4/4 with 3.54 gears and 4-speed trany whit granny 1st---the guy says its in a 1971 LTD did they make a 4-barrel in that model year LTD SORRY for the long post --thanks guys
Old Sep 22, 2004 | 10:57 AM
Kemicalburns's Avatar
Kemicalburns
ok first the cam would need changing because it meant for a car. now for the really sucky part. your truck never came with that motor so finding the towers that bolt to the frame are not existent. i tried this with my 73 ford highboy a few years back and got rid of the 351w because of it and went to a 390 which in my mind is way better then the 351m/400 anyday. there is also more aftermarket for the 390 as well.
Old Sep 22, 2004 | 11:18 AM
loudfords's Avatar
loudfords
It would be a good motor for your truck, should have decent heads on it, but yeah, you might want to change the cam. As for mounting it in your truck, 302/351W/351M/400 towers are all the same, you just need a set of truck 302 motor mounts. What engine is in the truck now? You will probably need to change the bellhousing and clutch on the tranny to complete the swap.
Old Sep 22, 2004 | 11:37 AM
jpb222's Avatar
jpb222
I have a 351W in my 76 f-150 4x4 it was a pretty easy swap. All you need is 351m/400 motor mount perches (ford never put a 302 in a 4x4 in the 70's) , The hole will need enlarged slightly but that is all. Next you need a bellhousing from a 300 six and you will be readdy to roll.
Old Sep 22, 2004 | 11:40 AM
jpb222's Avatar
jpb222
by the way where in PA are you located?
if you are close to somerset you are welcome to stop buy and take a look at my install and go for a ride to see if you like the power of a windsor.
my truck is similar to yours. 3:50 gears and an np 435 4 speed
Old Sep 22, 2004 | 12:01 PM
Kemicalburns
are you sure about this, reason i say this is because his frame may be wider or narrower which would create a problem thats at least why i couldnt use the 351m mounts in my 73
Old Sep 22, 2004 | 12:52 PM
butchf250's Avatar
butchf250
351w
little far im over in indiana pa but hey thanks for the invite--it has a 400 in it right
BiltFordTuff
May 12, 2011 08:32 PM
Stephen67
Oct 28, 2009 07:34 AM
49fordf1
43
May 24, 2008 08:05 AM
ken's1971
Apr 1, 2005 12:32 AM
cougar_1987
Aug 8, 2004 05:34 PM
