A chip for the computer possibly. The computer is always going to want to keep it around 14.7:1, so even if you richen it up, say with an adjustable fuel pressure regulator, the computer would probably compensate the other way. Why are you looking to richen up the mixture?
There's a code for carbon buildup? Might try replacing the O2 sensor first, and if that doesn't work, then you might be able to correct it with an adjustable fuel pressure regulator.
a gt40 motor was $800 bucks? thats a spendy motor in the ford cataloge
hows the compression and oil pressure. if the plugs are looken white could also be some antifreeze getting into the cylinders.
you work at a yard , thats the extreme hook up right there. well try the other stuff first and go from there. you may also adjust the timing back to say 8* in the mean time
