2wd 4wd FE part differences
Old Dec 28, 2013 | 01:47 PM
PHXCobra's Avatar
PHXCobra
What are the main differences in the FE for 2wd and 4wd? I turned my old motor in as a core and the one I got had a set of headers.
Is there a difference in the oil pan? I seem to remember my original engine had a rear pickup for the oil pan and the new one is in the front.
Are the headers different from 2wd to 4wd?
Old Dec 28, 2013 | 02:09 PM
HIO Silver's Avatar
HIO Silver
2WD oil pans are front sump. 4WD is rear sump...ya need the corresponding pickup tube.
Oil filter housing... 2WD is horizontal, 4WD is 90°.
Header differences? Yes. 4WDs don't have to deal with the 2WD crossmember and steering linkages... 4WDs locate the links in front of the axle.
lurch460's Avatar
lurch460
Yeah 4x4 have different oil pans. Dipstick is on front and front sump on 2wd. Think sometimes the oil filter adapter can be different too. I have a car one or 2wd truck one on my 390 and it sticks the oil filter straight out the side instead of making it up and down. Think I have a front sump pan on mine, it clears the differential because of the lift, haven't had an issue yet.
Headers are different too from 2wd to 4wd. Try them they might work.
Old Dec 28, 2013 | 02:32 PM
PHXCobra's Avatar
PHXCobra
Ok so I have to pickup a different oil pan and pickup tube, oil filter mount, and possibly dipstick. Will the headers work?
Old Jan 2, 2014 | 08:34 AM
PHXCobra's Avatar
PHXCobra
Bump for the header question.
Old Jan 5, 2014 | 02:41 AM
Rory428's Avatar
Rory428
2wd headers are different than 4x4, also 4x4 F100/150 are different than F250 4x4, due to different suspension (front leaf springs on F250,coil springs on F100/150).
If the "new" engine was from a 2wd, you will also need the special main cap bolt that has a stud to support the 4x4s longer oil pickup tube. The 4x4 pan has the dipstick tube located in the pan itself, on a 2wd (or car) FE, the dipstick goes into a hole in the block, just behind where the oil filter adpater bolts on. If you use the 4x4 pan setup, you will need to plug the hole in the block to prevent an oil leak.
Old Jan 21, 2014 | 10:15 AM
PHXCobra's Avatar
PHXCobra
Ok, now I am on the hunt for an oil pan, dipstick tube (could always use aftermarket, they are cheap enough), downward facing oil filter mount, pickup tube, main cap bolts.
The oil pan is proving difficult to find unless I want to spend $250 from Summit.
Downward facing filter mount I haven't even begun trying to source, if anyone knows someone who has one let me know please.
Pickup tube I hope O'Reilly has one for a rear sump.
Main cap bolts I would assume I could buy a set of ARP's or similar and they would have that one odd bolt in the kit.
Anything else I am missing?
brian138
May 18, 2019 05:14 PM
PHXCobra
Jan 31, 2014 09:08 PM
FarmerFrank
Feb 20, 2010 09:23 AM
flcbell
Jan 7, 2005 10:06 PM
ford390gashog
Jun 8, 2004 09:48 PM
