Automatic trans for my 57
Thanks, Derek
Barry
Fordomatic, Mercomatic and Cruisomatic were built for Y's, 1954-64.
Parts and repairs are very pricey.
The Ford-O-Matic bellhousing for trucks differs from the car units. Also, FOM trucks had provisions for water/oil heat exchanger while the '55 cars were merely air cooled. To put an automatic into a truck, you'll need to locate a truck bellhousing for an automatic. Another option is the C4 kit from Flatomatic
http://www.flat-o.com/carproducts/yblock.htm I think most "trucks" with ATs will have the c-6 as it is much beefier than than the c-4.The C4 was available on all but the wildest SBF's in cars, the C6 came with the big blocks.
Light duty trucks with the 240, 300 & 302 had a C4. Ask Gene Benson at FlatoMatic which years he thinks are best. The C4 is the racers choice since it is an extremely effecient design and loses very little HP. Lots of mods available for up to 750 HP in drag applications plus it is cheap to obtain and build semi stock.
The C6 is a dog by comparison. Hey, you're going to need a cross member for that c-4, or something as basic as a tranny X member? <TABLE style="WIDTH: 629pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=838 border=0 x:str><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17>C4</TD><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; BACKGROUND-COLOR: transparent" x:str='Built from 1964 - 1981? 17.18" long overall. C4 bell housing is removeable, C6 is not. '>Built from 1964 - 1981? 17.18" long overall. C4 bell housing is removeable, C6 is not. </TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; BACKGROUND-COLOR: transparent">Rectangular, almost square pan ( 10" X 9") with slight buldge on front pass. corner. Pan has 11 bolts.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; BACKGROUND-COLOR: transparent">5.0L engines tended to have C4s not C6s.</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" height=17></TD><TD style="BORDER-RIGHT: #c1ccd9; BORDER-TOP: #c1ccd9; BORDER-LEFT: #c1ccd9; BORDER-BOTTOM: #c1ccd9; BACKGROUND-COLOR: transparent">Not an overdrive tranny. Fairly robust unit. Can take a fair amount of power. Eats about 60 less HP than a C6.</TD></TR></TBODY></TABLE>Whatever you do Keep it Ford and have fun doing it. Keep on truckin. David
