Bellhousing Help
Old Apr 28, 2004 | 04:18 PM
57_Fordguy's Avatar
57_Fordguy
Bellhousing Help
I finally found someone with a bellhousing for my truck for $35 plus $25 S/H. The casting numbers on mine are TCAL 7505A. The place that has one is off of a 59 F250 with casting numbers TBAB 7505A , which is from a 292 w/ a 4 speed. Mine is the exact same motor/trans except mine is a 272. Does anyone know if these are the same things, will it work for my truck? Or should I have a welding shop attempt to weld mine, but I dont know how much that would cost, or if it will work. The crack in my bellhousing is right at the frame mount and is kind of seperated, It would have to be somehow held together before it is welded, which might be hard/impossible.
Thanks for the help, Derek
Old Apr 29, 2004 | 12:02 AM
Fordication's Avatar
Fordication
There is one on ebay for sale now. Ed
Old Apr 29, 2004 | 12:14 AM
pcmenten's Avatar
pcmenten
Derek, I've got two TCAL-B. I think one difference is that later trucks had hydraulic clutches and the bellhousing had the boss for the cylinder. I don't know the answer for sure, but I'd have to guess that the 59 bell would work.
Old Apr 29, 2004 | 12:29 AM
57_Fordguy's Avatar
57_Fordguy
Fordication,
What number is it? I cant find it.
Thanks, Derek
Old May 3, 2004 | 11:18 PM
My58Ford's Avatar
My58Ford
57 Fordguy!
There's a nice one on Ebay right now!
Check out item # 7901372695 !!!
Old May 4, 2004 | 12:18 AM
57_Fordguy's Avatar
57_Fordguy
WOOOHOO, lol. Thanks for telling me, I keep forgeting to look. just bid $50 on it, I have a feeling that its going to get a lot higher, but it is definatly something I need.
Old May 4, 2004 | 12:20 AM
57_Fordguy's Avatar
57_Fordguy
Wow, their is two of them, exactly the same and being sold by the same person
Old May 4, 2004 | 12:41 AM
My58Ford's Avatar
My58Ford
Hey if you miss the first one, you can always try for the second one!
Good luck!
dave vangsness
Dec 31, 2012 08:46 AM
pcmenten
Apr 11, 2005 07:37 AM
sierrabound
N. California Chapter
Feb 10, 2004 01:09 PM
gray79f250
15
Jun 11, 2002 07:15 AM
