Oil & Lubrication
Stp
Old Sep 18, 2004 | 03:46 PM
JohnAW's Avatar
JohnAW
Stp
Does anyone use STP any more? I can remember back in the 1960's and 70's everone was talking about STP, but I did not like the looks of it because it was so tick and gummy I just could see what it would do.
What is the latest on STP today?
Old Sep 18, 2004 | 03:54 PM
Mojave2k's Avatar
Mojave2k
All STP ever did as far as I know was to raise viscosity of the oil, which of course would help with low oil pressure in an old worn engine.. High viscosity oil is not recommend for the new modular engines. If I did have an older engine that was using oil I would just go to 20/50 and be sure to let it warm up before driving. High viscosity oils have been known to blow off oil filters on modular engines when revved cold.. Just an FYI. and MHO..
Old Sep 18, 2004 | 05:45 PM
Steven@nd's Avatar
Steven@nd
Yeah, my 95 Tbird with 4.6 mod had 110 psi oil pressure when cold! I'm surprised the filter never blew with 5w-30! Ran about 70 psi hot at idle...
STP is garbage - neighbor used it in an old truck, when the engine finally went he took it apart and found a tar-like substance on EVERYTHING. Instead of cleaning it he bought a different engine...
Old Sep 18, 2004 | 06:05 PM
JohnAW's Avatar
JohnAW
You said a mounth full there, that is way I was always affaird to use it. For once I did something right and I am glad I stayed away from it.
Old Sep 18, 2004 | 10:58 PM
aztec12's Avatar
aztec12
i can only tell you that there are better products out there.
Old Sep 20, 2004 | 07:23 AM
DOHC's Avatar
DOHC
What is the flash point of STP ?
Old Sep 20, 2004 | 08:55 AM
TallPaul's Avatar
TallPaul
I would think the best use of STP is to get up enough compression to drive a junker to the junk yard rather than paying to have it hauled away.
Old Sep 21, 2004 | 07:53 PM
Loan Ranger's Avatar
Loan Ranger
A MSDS for STP (part number 65148) would give the flash point. If I remember correctly, you can get the MSDS online at www.STP.com.
I have always understood that if one uses a quality motor oil, STP has no worth and may even be detremental. I have heard several persons who say it builds up a tar substance thorughout an engine. The hotter the engine runs, the heavier the build-up.
Old Sep 23, 2004 | 01:16 AM
peppy's Avatar
peppy
Good Stuff.......I used to put it in the Fairmont. I never changed the oil.....just replenished what I leaked and burned with STP. Figured it broke down about as fast as I put it in.
Worked great....I'm sure the motor siezing had nothin to do with the oil.
Old Sep 23, 2004 | 07:32 AM
jimlj's Avatar
jimlj
I remember as a kid riding my bike to the Esso gas station and getting STP stickers to put on the bike. To this day I swear it would go faster with the sticker, so the stuff must be good!
wavinwayne
Oil & Lubrication
Nov 28, 2008 12:54 AM
The_Ryan_Lilly
Oil & Lubrication
Jul 25, 2005 01:44 AM
chasparham
General Automotive Discussion
Jan 10, 2004 07:20 PM
Jupiter Coyote
Oil & Lubrication
30
May 10, 2003 07:23 PM
a63unibody
Aug 29, 2002 09:30 PM
