Its all in the filtration
Hey there anyone ever heard of gulf coast oil filters? I was talking to a trucker the other day and he put GCF bypass oil filter on his rig and never changes his oil, he just puts new filter elements on. GCF says that you never have to change the oil with there bypass oil filters, and they have proof to back it up too. A truck went a million miles with no oil changes just replacing the filter elements and the engine was broken down and there was no measurable wear on the bearings! And the engine was comletley clean with no sludge whatsoever. All it needed was some new rings. I contacted GCF and they do make a filter for our old Fords for 140 bucks. I am seriously considereing it because it seems that my engine would last a long longer with a bypass oil filter.
http://www.gulfcoastfilters.com/index.html
What were the UOA Results?
Good filtration is one thing, TBN numbers are quite another! If his TBN dropped below 2, even with great filtration, that oil would not be working. Did the oil shear out of recommended viscosity? A UOA would determine wear metals, presence of anti-freeze, fuel, silicon, etc. It's more than just great filtration which allows extended OCI's!
Bypass filters are very popular with diesels because they produce a lot of abrasive soot. Gasoline engines will not benefit much at all, especiallly modern fuel injected ones in good condition. I heard the argument a long time ago that oil itself does not "wear out", it just gets dirty. That is simply not true. Hydrocarbon molecules will oxidize and form thick, but not solid, acidic compounds, polymer additives will shear and also oxidize. As stated above, TBN will deplete, fuel and water cannot be filtered out. I am a proponent of extended drains, but only with UOA.
Jim
Jim
I read this at the link provided...
I have not seen the info on how much extra oil is added with a smaller gas engine filter change....
Although Gulf Coast doesn’t call this filter change an oil change, the fact remains that when you replace their filter and add the make-up oil, 6-quarts, you are adding lots of fresh oil with this partial oil change. Forty percent of your original oil capacity of fifteen.
I would want to see independent UOA's showing oxidation, nitration and TBN results. When the "proof" comes from the manufacturer of the product being sold I am skeptical. If something seems "too good to be true" it usually is. Testimonials from satisfied users are good marketing tools, but are not a substitute for scientific testing.
Jim
Jim
Jim
Jim
Originally Posted by FORD352V8
Of course I agree and if you read my post I said I had talked to numerous people who have used it as well. It not just a company claim.
I understand if you change the oil filters, you replace enough oil sooner or later to replace it all...therefore, you actually do change the oil. I understand the belief that toilet paper filters out crap in your oil...after all, it was designed to filter crap.
But what fun is it to never change your oil? I can see extendeding it out 10 or 20k miles...but to never change your oil.
I'd have withdrawl.
I'd have withdrawl.
Originally Posted by mountravlr
If filter changes involve adding significant amounts of oil in the process, it's not hard to understand that the oil stays fresher than if the oil was never replaced at all, as was originally represented: "It's All In The Filtration". Slightly misleading!
Lot of pros and cons and marketing on this.
One problem with most of our trucks is that there is very little room under the hood for one of these filters. Many of these filters are about the size of a big can of coffee, or bigger. Heck I had trouble finding a spot for my tranny filter on my F250, it used standard size spin on oil filters.
My grandfather used to sell what was called a Prelin Oil Refinery. Essentially a bypass filter with a heating element in the lid. It used gauze, like medical bandages as the filter element, with a top filter felt pad to keep the gauze from depositing particles. The heating element was supposed to heat up the oil enough to vaporize the water and fuel. This filter was very similar to what I have seen on some big rigs. The gauze also was supposed to absorb and hold all the nasty acids, water etc. It looked like it was doing a decent job of filtering.
I am not a professional mechanic. I just tinker and like to look at stuff, so don't trust everything I say to be correct.
Their selling point was oil didn't wear out. They did recommend normal mileage filter changes of the full flow filter and something like 25K or 50K on the gauze bypass element. My guess is that due to the 1qt every 3K or so and about 4 qts every 25K-50K, that the chemical additives in the oil were "replenished". I think they even marketed it that way. The oil in his truck always looked dark honey color and his truck did seem to run smoothly and quietly, and he ran his truck for something like 150K miles before his son rolled it.
I personally would be nervous about using this sort of filter. I just don't feel right about not changing the oil. If I were to do this I would use a syn and probably run some analysis every once in awhile.
I actually still have one of these "refineries" new in the box in the garage. I never used it because like I said, I am nervous. Plus I didn't want to drill holes in the pan(or drop the pan) and at least on my 250, there just isn't any room. One of these days, I might get brave enough to try it out.
I still feel that regular oil and filter changes are the key to long life and when compared against a blown engine, they are dirt cheap. Besides I like to work on my rigs.
Jim Henderson
Jim Henderson
