4” Down-Pipe – Resonator Question
Old Sep 20, 2004 | 01:35 PM
Choctaw Bob's Avatar
Choctaw Bob
This is what has kept me from installing one so far. It appears it is a pretty hard job, especially by yourself. The down pipe sometimes requires more room to install than you can get with a jack on your driveway. Alignment is critical so it doesn't rattle on the body, frame or axle.
Stainless looks better. It is up to you to decide if it is worth the difference.
Old Sep 20, 2004 | 01:50 PM
wolffee's Avatar
wolffee
Thanks for all the help....
Old Sep 20, 2004 | 06:27 PM
bighoss550's Avatar
bighoss550
Originally Posted by ClubDrof
No I'm not thinking of the cat. The resonator is part of the down-pipe and is very obvious from beneath the truck. Now that the 4” down-pipe with resonator has been installed the whine is noticeably less.
Thank you for the reply Tim.
was the whine really THAT bad without the resonator? i have an 03 and plan on a non-resonated DP and 5" pipe into a single 5.5" stack. i want it to SCREAM!!!!!
i mean glass shattering........
Old Sep 20, 2004 | 07:37 PM
Choctaw Bob
better make it a 12" stack!
Old Sep 20, 2004 | 08:21 PM
ClubDrof's Avatar
ClubDrof
The turbo whine (whistle) was too loud at low RPM, even when I was just sneaking out of the neighborhood; I mean in speeds less than 10 mph. The resonated down pipe still 'whines' but just when you get on it hard.
None of the morning walkers are covering their ears when I pass them now. That’s the only thing I miss…the little old ladies shaken their fist at me.
Old Sep 20, 2004 | 11:04 PM
npccpartsman's Avatar
npccpartsman
CB--I did mine on ramps in the driveway--unbolted the tranny crossmember and took the stock out in replaceable pieces. Wished I'd had lift access tho--would have been lots easier and probably only taken a couple of hours. I put in the 3.5" downpipe system. It really was a chore and still don't have the alignment of the pipe quite right--one hanger bumps the frame occassionally. The downpipe will come out if you wiggle it just right and the replacement goes in very easily since it's quite a bit shorter than the stock.
Old Sep 21, 2004 | 07:09 AM
jdadamsjr's Avatar
jdadamsjr
As npcc says...
the "extraction" is the real battle....
I did not care about going back to stock and so I told the guy that did mine to go from the bottom and cut it as high as he could before loosening it...
trying to be a nice guy... he tried to take it out whole...
he and another worked on it for 45 minutes before they finally gave up and cut it like I suggested
having done a lot of work for me in the past, he knew I wouldn't be happen if they took too many pieces off to save the stock CRUSHED downpipe...
( I still have part of it and it's amazing what a piece of engineered junk that is !
Old Sep 21, 2004 | 07:42 AM
Choctaw Bob
Where did you get the ramps that are rated for 3,000 plus pounds each? I would like to have some.
Old Sep 21, 2004 | 08:10 AM
jdadamsjr's Avatar
jdadamsjr
Good catch there Bob...
I have folded some ramps in my time too....
sure glad it happened before I got under it to put the jack stands and all
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Those had to be a bit expensive.....maybe custome made!
Old Sep 22, 2004 | 05:57 AM
npccpartsman
Lets just say they didn't come from Wal Mart
Old Sep 22, 2004 | 07:14 AM
SBV45's Avatar
SBV45
The Ford maintenance manual says to remove the crossmember at the trans with a trans jack under it and lower the trans about an inch when removing the down pipe. Interesting.
Old Sep 22, 2004 | 08:29 AM
  #28
Choctaw Bob
A sawzall will make a new joint in the pipe in front of the cross member. Most new replacements are short enough that you don't have to mess with the cross member.
Old Sep 22, 2004 | 06:22 PM
  #29
npccpartsman
I promise they were nothing you could buy at Walmart--25 plus years in the ironworking business tends to net one real stuff--not that mmmmm..........cheap.......junk--LOL.
hmmmmm-=-didn't mean to double post--must be having browser difficulties
Old Sep 22, 2004 | 07:56 PM
  #30
Choctaw Bob
Or too many beers!
