1996 F150 push button low range
Old Dec 28, 2014 | 12:35 PM
427mike's Avatar
427mike
Hello,
Our 1996 F150 4x4 automatic (BW1356) goes into high range with no problem but not low range. I have read many post and printed out the troubleshooting steps. Shift Module self test good, neutral signal good, speed sensor should be 225-275 ohms mine is 282.2 is that the culprit or is that close enough? Also the shift motor positions do not match the chart at all. I removed the encoder from the motor and spun it by hand and did get some open and closed signals. My question is will 4 wheel high always work even if the motor/encoder position is off? I found a dorman replacement motor for $80 but want to make sure that is the problem. I also bought a early 90s bronco electric shift BW 1356 t-case for parts in case I have a internal problem so if anyone needs parts let me know.
Old Dec 28, 2014 | 01:36 PM
Conanski's Avatar
Conanski
FYI.. truck must be stopped with the trans in neutral to enter or exit 4low.
gnuiver
1978 - 1996 Big Bronco
May 9, 2007 07:43 AM
dragonas964x4
Aug 23, 2006 07:18 PM
COLEnMICHAELS66
Aug 8, 2006 05:37 AM
bIIcool
Offroad & 4x4
Dec 28, 2003 10:00 PM
kell3238
Sep 17, 2002 10:13 PM
