what kind of brake hose do I need
Hello to all. I have been hard at work rebuilding the brakes on my 65 F250 and have replaced all lines and the master cylinder and after this weekend should have my front discs. Here is where my confusion sets in-I ordered a new rear flexible hose from National parts depot and when I got it, it was not the same part that was on my truck. The one I got is straight with threads at one end and the c-clip on the other. The one that came off the truck has the c at one end but has a T and double threads for the rear brake lines. It doesn't appear the T block off the old one comes off. Did I just get the wrong part or am I overlooking something. Thanks
Originally Posted by jowilker
Robert, This is interesting, All of my trucks have hard lines on the rear. The rubber hose is used at the front because of the steering rotation, and there is none back there.
John
John
Look again, you have one rubber line in the rear, not at each wheel, but where the line goes from the frame to the rear axle, which moves up and down with the suspension.
Al
It surprises me you're getting the wrong part from truck specific vendors. Getting the wrong part for a 65 at the Advance/Carquest/etc is pretty common. I've found that the computer system is wrong at these places...it thinks the 65 is the same as the 64. At my Parts Plus the only V8 engine choice in their computer for 65 is a 292! I've just learned to tell them it's a 66.
