Driver Window Off Track
Old Sep 16, 2004 | 07:54 PM
blksbeach's Avatar
blksbeach
I have a '98 Expedition. Couple of days ago driver-side window started to rattle (fully up/down or in-between), then today while lowering window the glass tilted forward about 45 degrees and got hung up. Was able to get glass realigned and fully up.
Question: Best way to remove door panel and tighten window hardware.
All else seems okay (i.e. weather stripping, tightness of closed door, etc.)
thanks
Old Sep 16, 2004 | 09:21 PM
JerNla's Avatar
JerNla
That happend to our 2002, still under warranty so we brought it in. They had to replace the window track.
Old Sep 20, 2004 | 11:12 AM
blksbeach's Avatar
blksbeach
Found culprit. There is a screw, washer/nut combo on either side of window track (front/rear) that connects to the window (rise/lower) assembly. Removed interior door panel. Screw, washer/nut combo was missing. Found hardware inside and bottom of door. Retrieved, put hardware back in place, tightened both (front/rear) screw, washer/nut combos and all works fine. Approx. 35 minutes.
Old Dec 23, 2004 | 12:30 AM
Abnsteel06vette's Avatar
Abnsteel06vette
i was told you have to glue the glass to the brackets...what kind of glue did you use?
Old Dec 23, 2004 | 10:14 AM
great white's Avatar
great white
On my 98 expy I had the adhesive fail and the window became separated from U-channel bracket. After many calls and estimates ($50-$200) I ended up doing it myself. I went to painters supply and picked up a structural urethane product ($20). Took me 30 minutes and back to normal. Make sure the window is clean where it contacts the u-channel before applying new urethane.(I used dremel with "soft" wire wheel to remove old adhesive).
Old Jan 3, 2005 | 12:43 PM
The Besh's Avatar
The Besh
Angry Driver window off track
I had the exact same problem on my '97 Expy, but my only way out was to
pay my friendly Ford dealer $295.00 to fix it ! Sounds like this should have been a recall item.
Old Jan 3, 2005 | 03:14 PM
Abnsteel06vette
I paid 6 dollars for the glue and did it myself...real easy....and its working great....
Old Jan 3, 2005 | 06:15 PM
oasebastian's Avatar
oasebastian
This just happened to my 97 exp. (driver's side)I even posted how I fix it. On the 97 there are 3 screws to be removed so the panel could slide up and then out. Remove the power window/lock switches. On top inner part of the openning, you will see the screw. Then remove the small plastic panel by the side view mirror (inside the vehicle) and you will see one more screw. Then remove the reflector lens and remove the screw. Now you will be able to lift the panel and pull it out. I used silicone glue I bought at a Walmart . Good luck
smallello
Jun 2, 2016 08:29 PM
stil190
Aug 8, 2010 05:06 PM
boggerted
Mar 18, 2010 02:32 PM
sign_man
Sep 3, 2009 05:05 PM
phoneman71
Nov 13, 2004 03:44 PM
