Door glas interchange
Old Sep 2, 2009 | 10:13 AM
sign_man's Avatar
sign_man
Cool Door glas interchange
My driver's door glass was smashed to steal my GPS . It's a '95 F250. I took the glass from an '85 and it rolls up fine till about half way then it gets really tight. I removed all the glass out of the weatherstrip and the electric window motor worked great before so what happened? On LMC truck's site they break out the years 80-86 and 87-96. The roller on the bottom track is different and the track on the 95 is made a little different, but nothing I would think that affects function. I did notice that the division bar between the vent window and door glass is wider on the '95 than the '85. Did they change the width of the window glass?
Old Sep 2, 2009 | 04:44 PM
Conanski's Avatar
Conanski
It could just be the rubber seal in the front track is pulled out a little now... guessing you dropped the vent window to install the new glass? Maybe try loosening the vent window assembly and put the main window up before you TQ it down.
Old Sep 3, 2009 | 02:24 PM
sign_man's Avatar
sign_man
Heck I've even tried it with the two screws out and the bolt removed for the vent.
Old Sep 3, 2009 | 05:05 PM
preppypyro's Avatar
preppypyro
I did this swap on my truck years back, because I had a 81 parts truck sitting around.
You have to change the divider, in my case I had the exact same thing happen, changed the divider, and it has worked well for 5-6 years now.
AmeriKen
18
Dec 9, 2019 11:40 AM
Amicus
Sep 2, 2016 07:23 PM
AeroZona
Aerostar
Sep 17, 2013 02:25 PM
1954_NJ_F100
Mar 24, 2013 08:55 AM
skimtn
13
May 7, 2012 11:23 PM
