oil changes...what a joke!
Old Oct 6, 2004 | 08:31 PM
  #31
baitmaster's Avatar
baitmaster
horizontal filter
My 4x4 had the horizontal filter before I added cooler and adapter. There are actually several shorter filters made by different companies that mate up like the PH8A. I have the list somewhere, if someone needs it.
Old Oct 7, 2004 | 12:51 PM
  #32
"Beemer Nut"'s Avatar
"Beemer Nut"
bad key pad
bodabdan, it's not the cap lock this time, it's orange juice that ate away on the silver circuits on the plastic sheets. This last "clean up" would of been the fifth time inside the key pad, i'm cheap but a new one is on order,thanks. Carl
.....o&o>....
Old Oct 14, 2004 | 08:01 PM
  #33
baitmaster's Avatar
baitmaster
short filters
Just installed an oil cooler kit on my '72 390 4WD. It lists approx 7 filters that are shorter than the PH8A. Almost every brand has a sub, if you need it. I have always used the Fram with no probs, although I relocated filter to inside of left frame horn in vert position.
Old Oct 14, 2004 | 09:19 PM
  #34
"Beemer Nut"
oil filters, longer the better (she said with a grin)
Fram PH8A is standard lenght, Fram PH977A is 7" long as well as the Hastings 426 ( cotton media) better than fram. Between the two filters in length is Fram 2815 for those who can't decide. The more filter area, in the the filter the less chance of going into by-pass as well as less pressure drop across the filter. Carl......o&o>........
Turbo Dog
2009 - 2014 F150
Dec 12, 2016 10:45 AM
davidrozeboom1
Aug 17, 2016 10:16 AM
JKBrad
2015 - 2020 F150
Jan 30, 2016 04:32 PM
Aaron-71
Jul 27, 2015 09:34 AM
Texasknowhow
Jan 28, 2015 09:01 PM
