oil changes...what a joke!
Old Sep 25, 2004 | 09:19 PM
AK429's Avatar
AK429
yea and the back of your hand gets really oily
Old Sep 26, 2004 | 01:43 PM
Almost_A_Merc's Avatar
Almost_A_Merc
I just rebuilt my engine which gave me the chance to "re-engineer" this thing
I just got done rebuilding my 390, so while I had it out I actually welded a new drain plug location into the front of the pan. I had to create a new "low spot" in the pan to allow it to drain right, but this allows me to drain the oil from the front and miss that crossmember. When I first got this truck I thought for sure someone had put a car oil pan in it. I just couldn't believe Ford would let something like that go off the assembly line... guess not.
David
Old Sep 26, 2004 | 07:05 PM
flyboy2610's Avatar
flyboy2610
My truck had a 1 quart oil filter on it when I got it. Shortly thereafter the crossmember "Violated the structural integrity of the filter".
Ya'll aint never SEE'D such a mess!! Oil ALL over the driveway!
Went to the big chain store where they are read in 'advance' and they kept telling me that the filter I had was the one I HAD to have. I went to a REAL auto parts store, told the parts guy what had happened, and without looking at the book or computer he said "Oh, you need a 3/4 qt. Dodge filter. Here, this will work." I took it home, installed it, and have no problems with oil changes since. I no longer have to jack up the ngine just to get the filter off.
Here are some part numbers:
Purolator L-20081
AC PF20
Wix 51068
NAPA 1068
Fram PH43
Chrysler 3549957
Hastings LF 196
Hope this helps.
Old Sep 26, 2004 | 08:39 PM
GolferSA's Avatar
GolferSA
Originally Posted by flyboy2610
Hope this helps.
All except for the part where you still have to remove the drain plug.
I use the specified oil filter on my FE, haven't encountered the problem you describe.
Old Sep 26, 2004 | 11:40 PM
towrig302's Avatar
towrig302
Just did my 1st oil change on my 'new' '71 F250...
...and I just made a simple 'drainage ditch' out of aluminum foil. Cheap, clean, and easy. Brian
Old Sep 27, 2004 | 02:55 PM
Freightrain's Avatar
Freightrain
Standard ol' "FL1A motorcraft" on my stuff. Never been a problem.
Old Sep 28, 2004 | 10:05 PM
ceetwarrior's Avatar
ceetwarrior
FL1A Motorcraft for me. Fram is PH8A, same filter they used for almost 40 years on everything.
Old Sep 30, 2004 | 07:34 AM
Highboy70's Avatar
Highboy70
Michael, another thing you can do with the filter( if you have a 352 series block) is look around the junkyards for a filter mount that drops the filter down vertically. I found one of these that fit mine and wow what a difference! I can actually take the filter off now without the usual splash. I can't give you the exact application that had these, but their out there.
Old Sep 30, 2004 | 08:17 AM
Freightrain
My '64 Galaxie has the hang-down style holder. Not sure what others had this style.
Did not think there was enough room for this on a truck?? Apparently there is! Maybe only on 4wd models??
Old Sep 30, 2004 | 09:32 AM
Mike G's Avatar
Mike G
The vertical oil filter was used on cars and 4x4's. Unfortunately, the filter is a tad on the long side when mounted this way on a 4x2. There is a short filter that will compensate for this, but that opens up a new can of worms...
--Mike
Old Sep 30, 2004 | 10:16 AM
towrig302's Avatar
towrig302
I think the vertical adapter was also used on Econolines-what years I don't know. I see these adapters on 'e-pay' regularly. Brian
Old Sep 30, 2004 | 07:41 PM
flyboy2610's Avatar
flyboy2610
--Mike
And can result in a huge mess on the driveway. My 4x2 has the vertical filter and the first oil change I did I had to jack up the engine to get the filter out. See my previous post for 3/4 Dodge filters that will fit just fine.
Old Oct 2, 2004 | 08:00 PM
  #28
Highboy70's Avatar
Highboy70
Ah, but if you go to a PH16 oil filter, it gives you about another inch to and inch and a half clearance.
Old Oct 2, 2004 | 11:03 PM
  #29
"Beemer Nut"'s Avatar
"Beemer Nut"
Pan drain and oil and filter
I'm running a full length sump from a large truck that i welded a back up nut inside at the rear bottom area, clean oil drains without a frame lube. On oil filters i'm running a Hastings number four two six (i lost my number key function?) that's 7" long and a cotton media inside. While the sump is draining i'll punch a hole in the filter at the top end area to let air in with a automatic center punch. After 15 minutes add a piece of duct tape over the hole and remove the filter. A few paper towels are placed under the filter as a few tea spoons of oil will drip at the joint. Carl.....o&o>..............
Old Oct 3, 2004 | 02:58 PM
  #30
bodabdan's Avatar
bodabdan
Veteran: Navy
Check the numbers lock key. It gets me all the time.
