code p1316 "injector driver module fault"
Old Sep 14, 2004 | 11:22 PM
billy bob's Avatar
billy bob
Question code p1316 "injector driver module fault"
my wife was driving the truck and said it lost all power, wouldn't get over 20 mph.she stopped and shut truck off for a few mins. , started up again and ran fine for 10 mins. no power and rough idle. I've checked price on this module $1500+ ,I wouldn't think engine would run at all with a failed inj. module . any info and help is appreciated
Old Sep 15, 2004 | 12:34 PM
sy5adm1n's Avatar
sy5adm1n
I think that the P1316 means that the IDM, which is another computer like the PCM, has some fault codes stored in it. It doesn't mean the IDM is bad. See if you can get to a scanner and see if it is tripping any p127x codes. You will probably find one or more codes in the p127X range meaning open circuit between IDM and injector, with the x letting you what cylinder is having the problem. Also check the under valve cover harnesses to see if it may have come loose. I have seen alot of posts from people that said the plastic pieces get hot/brittle and come loose. I think there is a kit available for the little plastic pieces to lock the connectors in place. Retainer (Under Valve Cover Harness clips) Ford Part # 2C3Z-14A163-AB.
Old Sep 15, 2004 | 11:59 PM
billy bob's Avatar
billy bob
Talking
I found the problem and fortunately I couldn't locate the IDM on the truck anywhere and while looking for IDM I was checking for shorts in harness, I found a short to ground on main harness above left valve cover.sy5adm1n your advice is good , I talked to a ford mech. and he said my problem was either the IDM or injector failures
Old Sep 16, 2004 | 05:42 AM
sy5adm1n's Avatar
sy5adm1n
I'm glad it was something fairly simple. Seems I've had to wire tie more than a few harnesses off of something in the engine bay that were rubbing. Good luck with the fixes.
Old Sep 27, 2004 | 02:09 AM
CAPITALIST PIG's Avatar
CAPITALIST PIG
Thats exactly what it is, my 2000 excursion with same symptoms, thought it was gonna cost me several thousand to fix. but thank the stars it was just a clip on the INSIDE of the valve cover. Replaced and clipped both sides and saved thousands at a dealership, I had to pinch myself.
Old Sep 27, 2004 | 09:03 AM
Frobozz's Avatar
Frobozz
The IDM operates as two "banks" of injector drivers (right and left) - a fault on a bank can cause that bank to shut down, so then you're driving a V-4. That's why the original poster's wife found herself with a truck with no power. A power-off/power-on resets the fault condition in the IDM, and if it's an intermittent cause the truck can seem fine again until the underlying cause happens again.
Our 2000 X had an IDM that would be put into V-4 mode by, I kid you not, a really powerful radio transmitter tower along a certain road near my office. Every time you'd drive by that spot, it would drop 4 cylinders. I didn't normally drive it to work so we'd only had this happen 3 or 4 times while my wife had been driving near there. At work one day I convinced the guys to go out to lunch along that road so I could try it one more time to prove to myself that's what was happening. Sure enough, right in that spot, WHAM.... except this time the whole engine died! I coasted the beast (with its no-longer-power-steering-or-brakes!) into a parking lot... which happened to be right across the street from a Ford dealer. They had it towed over there, ordered an IDM, replaced it the next day, and I was back on the road. The new IDM was not haunted like the one that died, and we never had that problem again. My co-workers have never stopped calling me an idiot for saying "let's go see if we can get my truck to die along this road!" and then proceeding to do so, stranding us all during lunch...
Duncan
Old Sep 28, 2004 | 12:11 AM
Kwikkordead's Avatar
Kwikkordead
LOL, live and learn.
Old Sep 29, 2004 | 12:17 PM
nelgin's Avatar
nelgin
My dealer told me that the IDM was bad with code of p1298. Question-If the IDM is bad internally will the truck run? My truck runs good and doesn't miss or lose power at anytime. Do you all think the IDM is bad?
Thanks
Broncojunkie
19
Dec 19, 2014 07:53 PM
79f150ford
Nov 23, 2014 05:44 PM
Ndurbin10
Apr 1, 2014 07:17 PM
JasonWestern
Mar 12, 2012 12:15 PM
nlareau
Jun 16, 2011 06:10 PM
