1978 - 1996 Big Bronco
Rear Spring Hanger Replacement
Old Aug 23, 2010 | 04:24 PM
  #46
Matt8393's Avatar
Matt8393
I got the bushing out of the spring but have a couple more issues.
1. the new leaf spring bushing that I have has the metal sleeve around it. It will almost fit into the spring that still has the old metal sleeve in it. It appears to me that when I remove the old outer sleeve from the leafspring that the new bushing will be a little bit smaller than the hole in the leafspring and have play in it. Maybe I have the wrong bushing, it is the one that came with the shackle kit.
2. I got the hanger from Autozone and it the wrong hanger. It is for 3 in. leaf springs and mine are 2.5 in. But the shackle they listed for my Bronco is the right one.It is a Dorman 722-005 and is the only one they (as well as Advance) have listed for my Bronco. It appears that the Dorman 722-003 Hanger may be the correct one. It will be here on Wed. so I will find out then. I will do some research on it tonight and see if it is the right one or not. Any thoughts on why they only list the 3 in for a 1990?
Thanks again for any help. You guys are great.
Old Aug 24, 2010 | 12:45 AM
  #47
supercab4x4dually's Avatar
supercab4x4dually
1990 Fullsize Bronco has 3" wide rear leaf spring's.I would see if you can get the polyurthan bushing's which you can put in with your hand's.The rubber one with metal sleeve has to be pressed into spring.
Old Aug 24, 2010 | 08:19 PM
  #48
Matt8393's Avatar
Matt8393
Turns out I was given the wrong shackle. It fit the leaf spring but was too small for the hanger. So I got to get the right shackle and get the the hanger I took back yesterday back and all will be well.
If I get the poly bushings from Energy Suspension does it require the removal of the outer sleeve of the old bushing from the leaf spring? If so is pounding it out the best method or is there an easier way? Or any tips that would help me do it. I am doing this all from under the Bronco.
Old Aug 24, 2010 | 09:10 PM
  #49
supercab4x4dually
Yes take that sleeve out!Take a saw's all with a metal blade and cut it out.It's only tin.Take a hammer and a flat chissle and cut it out that way.I use my torch and cut it out.You can bend and pry it out if need be.
Old Aug 24, 2010 | 09:25 PM
  #50
Matt8393's Avatar
Matt8393
Looks like a job for tomorrow while I wait for the Shackle and hanger to come in on Thurs.
Old Aug 25, 2010 | 03:57 PM
  #51
Matt8393's Avatar
Matt8393
while trying to order the poly bushings a question came up. if I had common frame or molded in? I don't know for sure but I assume the common frame is the one with the outer metal sleeve and the molded in ones are the ones without the outer sleeve. Am I correct in my thinking?
Old Aug 25, 2010 | 07:17 PM
  #52
supercab4x4dually
Im not sure what you mean??I buy them as the poly bushing's.
Old Aug 25, 2010 | 07:25 PM
  #53
Matt8393's Avatar
Matt8393
common frame or molded in bushings. that was the choice they gave me for the poly's. not sure what the difference is.
Old Aug 25, 2010 | 09:33 PM
  #54
supercab4x4dually
common frame is what you want.That mean's there is no outter sleeve.JBG# 33158
Old Aug 29, 2010 | 11:19 AM
  #55
Matt8393's Avatar
Matt8393
I have had to resort to putting the bushing that came with the shackle in. the Boss clamped down on me spending money. being as I can"t spend money on it right now and can't pull the spring out of the truck, is there a way to press the bushing in from under the truck.
Old Aug 29, 2010 | 05:05 PM
  #56
supercab4x4dually
NO,It's pressed in
Old Aug 29, 2010 | 05:14 PM
  #57
Matt8393's Avatar
Matt8393
I got it pressed in using a 1/2 in bolt and some large washers. went right in. I will post a pic shortly.
Old Aug 30, 2010 | 04:36 PM
  #58
Matt8393's Avatar
Matt8393
Rigged up a press of sorts to get the leaf spring bushing in.
Old Aug 30, 2010 | 04:37 PM
  #59
Matt8393's Avatar
Matt8393
Here is the link to the Pic of it.
Ford Truck Enthusiasts Forums - Matt8393's Album: 90 Bronco - Picture
Old Sep 5, 2010 | 06:00 AM
  #60
XCHEVY's Avatar
XCHEVY
II**********||:::::::::::::::::::::::::::::
II*** F ****||:::::::::::::::::::::::::::::
II*** R ****||:::::::::::::::::::::::::::::
II*** A ****||:::::::::::: Gas :::::::::::
II*** M ****||:::::::::::: Tank :::::::::::
II*** E ****||:::::::::::::::::::::::::::::
II II**********||:::::::::::::::::::::::::::::
\\ II**********||:::::::::::::::::::::::::::::
II II .. \:::::::::::::::::::::::::::::
II-----BOLT----II***-----rotted
II II
