General Automotive Discussion
Connectors: Is there a tool ?
Old Sep 12, 2004 | 07:51 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
Hey, i need to remove and install come new clip/connector things in my 84 F150 fuse box (the little metal things with a wire coming into the back and the fuse plugging into the front.) Is there a special tool i can use to get this done? Thanks guys!
Old Sep 12, 2004 | 08:02 PM
F2504x4's Avatar
F2504x4
i have used a very small tipped straight blade screw driver, like the one's that fit in your shirt pocket.
Old Sep 12, 2004 | 08:05 PM
Samsonitesamsonite
i've tried that but i cant seem to get them out...
Old Sep 12, 2004 | 08:23 PM
F2504x4's Avatar
F2504x4
maybe be racerguy can be of help here, i'll send a pm to this thread.
Old Sep 12, 2004 | 10:02 PM
Samsonitesamsonite
thanks!!!!!!
Old Sep 12, 2004 | 11:08 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I have that tool. I think. You want to remove the wire, and the metal connector, from the plastic "casing"? Then yes, I do have that tool.
It is available from Snap On. I forget how much I paid for it though. It came in a kit with 7 other tools to do the same job on different kinds of connectors.
So, to answer your question, yes there is such a tool.
Old Sep 12, 2004 | 11:12 PM
pfogle's Avatar
pfogle
It's called a pocket screwdriver, this is how I've removed them in the past, you just have to be careful not to smash the connector, or break the plastic.
Old Sep 13, 2004 | 12:07 AM
Racerguy's Avatar
Racerguy
I have a set of Snap On tools too like bigrigfixer has but usually a small pick or screwdriver will work.
Old Sep 13, 2004 | 08:58 AM
Howdy's Avatar
Howdy
Molex is the name of the company that makes a lot of those type of connectors. Common name for the tool is a Molex tool if you're searching for one. (Kind of like searching for a Cresent wrench when it's really an adjustable wrench.) If you go to http://www.molex.com and enter tool on the sites search, you'll come up with all sorts of odd-ball stuff. If your an exotic tool junky - be careful.
Supercab
Nov 8, 2010 09:39 AM
larrylass
Electrical Systems/Wiring
Sep 24, 2010 06:34 PM
Irv Nichols
Jul 17, 2010 05:53 PM
ranger982
1983 - 2012 Ranger & B-Series
Aug 8, 2007 09:03 AM
charlesvalentine
Jan 31, 2002 10:24 AM
