Aerostar Ford Aerostar
PW Switches
Old Feb 20, 2001 | 09:31 AM
philcartier's Avatar
philcartier
PW Switches
have power windows in my '91. The switches, esp. the driver's side seem to break regularly. Are there any fixes or substitute switches available?
Old Mar 13, 2001 | 02:30 PM
kwulf's Avatar
kwulf
PW Switches
I have been unable to locate any aftermarket replacement. When my driver side switch went I had to go to the dealer.
Old Mar 14, 2001 | 07:32 AM
philcartier
PW Switches
that is a bummer. Ford wants about $75 bucks for the stupid thing and it is very poorly designed. I'll have to take it out and see how it works. Maybe the switch for a GM car will work.
Old Mar 14, 2001 | 12:12 PM
kwulf's Avatar
kwulf
PW Switches
$75 - Is that US or Can. I paid $60 at a dealer here in Canada for the drivers door which has controls for both windows. It took me all of 5 minutes to change. One screw holding on the outer panel, 4 (or 3) screws holding the switch plate on and the switch just plugs in.
Old Aug 20, 2001 | 11:37 PM
rdnck4x4's Avatar
rdnck4x4
PW Switches
[font size="1" color="#FF0000"]LAST EDITED ON 21-Aug-01 AT 00:37 AM (EST)[/font][p]two pieces of wire work fine(redneck ingenuity at it's finest),or if the wire is too fancy,you could break a paperclip in two pieces,then hot wire the switch
Old Aug 21, 2001 | 11:10 AM
aerocolorado's Avatar
aerocolorado
PW Switches
Go to website Ford Parts Network. I bought a new passenger side replacement for $16.00 recently.
Old Aug 21, 2001 | 11:31 PM
Ed's Avatar
Ed
PW Switches
One more note. When you have the door panel off, take some fresh white lithium grease and lubricate the gears, support bars, any part moving the windows up and down. It makes the motor work much more efficent, as well as quietly. Yes, those switches are cheap (as in poor quality. More than once I have wished my Aerostar had the simple, manual window cranks. When you can roll a window up or down on a car that has been sitting in a junkyard for a year with no problems, sometimes simple ideas are better than the convenience of power windows IMHO.
Old Sep 5, 2001 | 10:53 AM
philcartier
PW Switches
This problem has sort of been fixed. I got a new switch, the price has come down considerably, from $75 down to $38. The parts guy said it was a new number, with a "b" at the end which usually means a redesigned part. The levers looked a good deal sturdier and seem to be made out of a harder plastic. Hopefully it will hold up longer. I had been getting about 40K miles out of a switch.
Old Sep 6, 2001 | 02:54 PM
LiteTrader's Avatar
LiteTrader
PW Switches
57_ford
Jan 15, 2003 08:07 PM
Superdave
Dec 20, 2002 07:00 AM
steve83
Nov 12, 2002 11:53 PM
Kenny
Sep 20, 2002 11:30 PM
gregdatech
Apr 4, 2002 11:06 AM
