Starter Removal Help
Old Sep 11, 2004 | 06:33 PM
mmhud's Avatar
mmhud
How do you get to the upper mounting bolt and the connection to disconnect the electrical connectors. I tried a open ended and close ended wrench, along with socket wrench with and without extension. There just is not enough room to get in there. Has anyone else removed a starter from a ford explorer V6 automatic and how did you get it out?
I was told it is my starter by the autoparts guy but I want to make sure before I get it out, all I get when I turn the key is a rapid clicking. I have a lot of green buildup on my negative battery that keeps coming back after I clean it. I hit my starter with a hammer the other day to get the truck started so I could get it home. Is this for sure the starter, or does it sound like the cable or battery....
Old Sep 11, 2004 | 06:37 PM
jclj2003's Avatar
jclj2003
i used a specail adaptor that looks like a u joint that allows you to get around to the upper bolt
Old Sep 12, 2004 | 11:10 PM
samhihn's Avatar
samhihn
You mentioned corrosion on or in your battery cable. Don't ignore this. The visible green crud can be cleaned up even with something as simple as soda pop, but you may want to check the resistance of the cables themselves. You can actually get corrosion inside the cables that will cause a high resistance to current and make the circuit seem to have a dead battery. You didn't mention the year of your vehicle but on my '93 I replaced the starter only to find that ten year old cables aren't like new any more. Best of luck............mike
1986F150six
Jan 11, 2013 10:03 PM
1986F150six
'80-'86 HOWTO's
Jan 16, 2012 07:28 PM
Pete in Maine
22
Jul 21, 2011 04:32 PM
Gridrat
Mar 5, 2006 06:56 AM
Hennepin451
24
Oct 19, 2005 05:55 PM
