Since the Moderators Deleted the Previous thread (who knows why when it is VERY GOOD information to know!).....
FYI!
Ford changed the Clutch Lever (aka Bellcrank) starting in the 1987 model year. The biggest change was the OFFSET. There is at least a 1" difference in Offset between the old style lever.
The new style lever (87+) will NOT line up (behind the clutch master cylinder) properly in a 80-86 truck.
Q: Did Ford make a change in the location of the clutch master cylinder in the 87+ trucks to make up for the bellcrank offset difference from the previous years ???
Umm I found your post. I don't THINK it was moved because it didn't pertain to the forum I found it in (1987-1996 Ford Trucks). I think you put it there by mistake? Here it is anyways: https://www.ford-trucks.com/forums/s...d.php?t=281034
The pedal shaft is shorter, and the pedal bracket bracket and it's mounting is different(due to the different mounting of the 87-91 dash) IIRC, 92-96 is a different ballgame again.
An 87 pedal setup will NOT work with an 80-86 dash, you need 80-86. Or, possibly by some grace of god, some F600-1000 of later vintage(they used the 80-86 interior until 98) might have use a hydro clutch, but, I have yet to see one that does.
