epoxy primer & sealer
Old Sep 10, 2004 | 11:50 AM
kurt IA's Avatar
kurt IA
I have a 72 f100 i want to primer with ppg dp90. from what i understand there is no uv protection with the primer.(this truck will be setting outdoors)what can i put over dp90 to keep it from fading. and will this primer have any build value.
thanks.
Old Sep 16, 2004 | 02:38 AM
Rick Braden's Avatar
Rick Braden
Epoxy Primer
thanks.
I'm only a beginner with paint & stuff but here's my 2 cents worth. I've never heard of an epoxy that was uv resistant. I've had a lot of experience with fiberglass boat stuff & gel coating with a HVLP (high volume low pressure) sprayer.
Years ago I used DP90 & I think it was green. It had to be covered over to be uv resistant. As long as build value, the automotive paint store sold me some Kondar. That is a compatable high build primer that is grey I think. (was 12 years ago.)
I aslo think the Kondar states not to leave it exposed to weather because I think it could absorb moisture. You have to coat over that. What I did turned out excellent. I'm sure it took me hours longer than a pro but then again, I'm no pro. Hope this helps & the literature you get at the paint store with the DP 90 should tell you all you need to know. Take care, Rick
vidaliaman
Paint & Bodywork
Mar 29, 2017 11:59 PM
Jimmiej08
15
Jan 29, 2017 03:47 PM
avf100
Sep 4, 2016 01:45 PM
macs40
Paint & Bodywork
Jun 3, 2016 02:16 PM
jvmcc
Paint & Bodywork
Aug 29, 2013 08:31 PM
