02 F350 Leveling kit
Old Sep 9, 2004 | 12:24 PM
so2315's Avatar
so2315
I have a 02 F350 4X4 without the training wheels (duals). I want to level the front end as it sags with the PSD. Is it just a simple Add a Leaf or is it more detailed. If it is an add a leaf, can someone do this at home in driveway with floor jacks and 1/2 impact wrench or will a shop need to do it and redo the alignment?
Old Sep 9, 2004 | 12:55 PM
MRBASS's Avatar
MRBASS
I have a 02 F350 PSD also,,, I did the 2 1/2" Rough country add a leaf in my garage floor, no problem at all. I did remove the calipers as the brake lines were stretched pretty tight when i started to drop the axel,, have heard of people not removing the brakes though. Overall i think it was money well spent,, raised my truck about 2 3/8 in the front when it was all said and done. The truck dosent lean near as bad in curves now,but really I dont think the ride is any harsher at all. Its a firm ride on a bad road and a great ride on a great road much like the factory ride.. Just make sure you grease the leafs very well on both sides before you put them in,, It'll be messy but prevent the squeaks for a long while.
Old Sep 9, 2004 | 01:01 PM
KG7VL's Avatar
KG7VL
FabTech 3.5 leveling kit
Hi, I did my 02 PSD with the fabtech 3.5 leveling kit. I went to 16X10 wheels and 315/75x16 tires with no problems. Air tools are handy for the work, which I did myself in the driveway. You need a really tall set of jackstands to get the frame high enough to drop the front axle and get the new tires on. A jack that lifts high, is also nice to use. It is more than just a spring, and is an new frame piece for the front of the spring and a piece added and inverted for the rear. I would not do it without getting the adjustable track bar. Otherwise you end up having a hard time pushing the axle to the side to get the stock one to connect. Good luck, Mike KG7VL
Old Sep 9, 2004 | 03:57 PM
bjjf350d's Avatar
bjjf350d
I have as well installed the 2.5" tough country, I am very pleased with it and the way it handles. As far as re-alignment there are no real adjustments that the kit affects other than the track bar relocation which seemed to line up pretty well with the new bracket. I was able to install the kit in about 3.5 hrs in my garage. Do make sure you get tall jackstans though and have at least 2 jacks. Before the kit i had 4.5 - 5 " difference from front wheel well to back, it leveled it right up. brought the front up about 3.5" and the rear down an inch.
Old Sep 9, 2004 | 04:06 PM
so2315's Avatar
so2315
How about going into a standard 7 foot garage? Mine has clearance lights so it would be close.
Old Sep 9, 2004 | 09:02 PM
tjbeggs's Avatar
tjbeggs
there are many different kits out there with many different methods of lifting. some use leaves some new spring hangers. my experience have been with add a leaf only on old body styles and add a leaf with track bar relocatation bracket this was a tuff country or rough country can't remember which is which. both are pretty easy. use the advice already given. but as a mechanic i say to all of you get an alignment!!! the track bar is adjustable for a reason and your steering wheel will most likely be crooked. lifting a truck no matter what it is changes the alignment and alignment kills tires and bad tires cost money.
if you have any question just post em i will be more then happy to help
tjbeggs
Old Sep 10, 2004 | 05:26 AM
bjjf350d's Avatar
bjjf350d
Yes, Tbeggs is right, i forgot to mention the steering wheel alignment, I was able to adjust the steering bar link by turning the adjuster coupler. It took many trial runs down the road to get it right but in the end it ended up perfect. As far as the track bar it's purpose is to keep the entire axle aligned left to right. This can be easily adjusted by hanging a plumb ball on a string from the frame and measuring each side. As far as camber and tow these items are not affected because you have a solid front axle and are not moving the original spring position with the add a leafs and new centering bolts. Saved my self a good $60.00 and been going on 15,000 miles now with no abnormal tire wear.
Old Sep 10, 2004 | 09:50 AM
so2315's Avatar
so2315
how about getting it in the garage?
Old Sep 10, 2004 | 10:20 AM
bjjf350d's Avatar
bjjf350d
I have a 7' garage door opening but the actual garage height inside was 8'. Because the truck was on a down slope before the kit it kicked the back end of the cab up almost level with the clearance lights (crew cab). After the kit was installed the front of the truck raised up about the height of the cleareance lights and the back of the cab dropped down. I had about 3 to 4 " clearance on the way in the garage and about an 1.5" on the way out. If you get into a bind you can let air out of the tires to remove it from the garage. You definately need the extra height inside the garage though cause the truck must go way up on the frame to do the install.
Old Sep 10, 2004 | 12:15 PM
so2315's Avatar
so2315
I have a crew Cab 4X4 and it barely clears the garage door now, the rear of the cab is within 1/2" of door. Just wondering if anybody else did a bone stock F350 4x4 Crew Cab PSD and did it fir in the garage after?
Old Sep 10, 2004 | 04:29 PM
semperfipsd's Avatar
semperfipsd
Just talk to a local 4x4 specialist. They have the add a leaf leveling kit for around $180 and said they would install it on my 99 F350 PSD CC SRW for total just under $300. I didn't think that was a bad deal for just an extra C note! Will probably make an appointment for next week if I can afford to be without my PSD for an afternoon. They told me with the 2-2.5 leveling kit they havn't needed to use the track bar bracket and they wouldn't have to do a tire alignment. They would adjust the steering wheel.
Old Sep 15, 2004 | 11:26 PM
bravwolf's Avatar
bravwolf
I installed the 2.5" tough country in the driveway by my self with two floor jacks. The worse part fer me was breaking the track bar loose that thing was tight. I ended up taking a torch and heating the nut a little it come right off then and the kit had a new one with it. Make sure you retighted everthing after test driving.
Old Sep 22, 2004 | 07:55 PM
KCPSD's Avatar
KCPSD
Does the truck sit level or does the front seem to be a little higher than the back? I saw one that had been leveled and the front looked higher, not sure which kit he used though. I just got my Rough Country 2" kit today, so I wanted to ask you since you had the same kit.
Old Sep 22, 2004 | 08:19 PM
mybigredford's Avatar
mybigredford
i think the truck looks good without the leveling kit, i like the back end a little higher than the front, it looks tough.
just my .02
truckguymn92
Mar 10, 2016 03:47 AM
et_miller_87
Sep 20, 2015 11:45 PM
kras498
General Automotive Discussion
Mar 12, 2015 11:43 PM
icentropy
Sep 5, 2013 06:15 PM
The1999Beast
New Member Introductions
Dec 25, 2007 12:07 PM
