Im looking to replace my front leaf springs on my 01 f350 4 x4 7.3
Im also looking to add some lift to the front end while doing so. Ive heard that if I install the 3 leaf heavy duty springs they will add 2" of lift. Can anyone confirm this and does any one have any recommendations where to purchase springs online?
I just ordered some springs from Junior at ATS springs. I got some modded X codes for the front and modded C codes for the rear. He is very knowledgeable and will custom make the spring packs to what you want. He re-arched the X and C codes he sold me to give a little more lift than just an X and C code straight replacement. They are much less expensive than the dealer springs but for me, shipping to CA wiped out some of the savings. I still saved a couple of hundred dollars over what the cheapest dealer would charge. Customer service is top notch and he is always around to answer questions.
I think I just responded to an email you sent us from over the weekend. Let me know if you did not receive it or if you need anything else explained in more detail!
Fabtech has suspension systems as well as leaf springs for 2000-2004 F350 models. Check them out. I think you might find the right ones for your 2001 f350.
