Bug Shields
Old Sep 8, 2004 | 10:24 AM
ITDave's Avatar
ITDave
Bug Shields
Does anyone know what the difference is between these two FORD Bug Shields?
F-150 Accessories Catalog
Page 4-5
Item's 3 & 4
3. Low Profile Wrap Around Bug Shiled 16C900
4. High Profile Wrao Around Bug Shield 16c900
Ok, so I see that one says low and one high, but with the pictures they both look the same.
What is the difference between the two?
Which one is better?
Which one actually looks the nicest?
What is a good price for them (Installed/Non Installed)?
Thanks in advance!
Dave
PS Would you go with the side window deflectors, not sure if I like them or not...
Thanks again!
Old Sep 8, 2004 | 11:14 AM
Biggziff's Avatar
Biggziff
The lo profile shields are about 1/2" shorter than the others.
Seems like $40-$50 is about right for most of the brand name shields I've seen. Install time should be .5 hour.
Old Sep 8, 2004 | 11:34 AM
ITDave's Avatar
ITDave
Thanks BigZeff
Which one do you think looks better?
Most functional?
Maybe the extra inch would give you more lift over cab?
Thanks,
Dave
Old Sep 8, 2004 | 01:07 PM
Biggziff's Avatar
Biggziff
My opinion, the lo profile looks better, but the hi-profile probably works better.
Old Sep 8, 2004 | 01:30 PM
kingfish51's Avatar
kingfish51
Get the low profile. Less likely to get hood shake (do a search).
Old Sep 8, 2004 | 04:52 PM
ITDave's Avatar
ITDave
Thanks to you both, looks like I will get the low...
Old Sep 8, 2004 | 05:36 PM
didit26pt2's Avatar
didit26pt2
After vowing to never go back to the dealer around the corner from me (Greenway Ford), I was in a pinch and they were the only dealer in Orlando that had the bug shields in stock. Their part guy told me $84. I said that was insane and $20 more than the other dealers here were charging. Needless to say I walked out, vowing once again to never return! I ended up buying the "Lund" and am very pleased with it. It was a easy install as well.
Old Sep 8, 2004 | 05:38 PM
ITDave's Avatar
ITDave
Thanks for the input, does it say "Lund" on it? Someone recommended a Stainless Steel
Thanks for the input, does it say "Lund" on it? Someone recommended a Stainless Steel one.. Have you ever heard of or seen that?
Old Sep 8, 2004 | 05:47 PM
Biggziff's Avatar
Biggziff
stainless or chrome are just more $$$. I'd stick with plastic.
Old Sep 8, 2004 | 06:11 PM
Blue Blooded's Avatar
Blue Blooded
You can check mine out on my gallery. I have AVS(AutoVentShade)I would think this is low profile(they may even make it for Ford)
from Pep Boys(believe it was less than $50). Pretty easy to install(just have to remove grill). IMO I haven't seen any that look better.I still get some bugs on the windshield, but I bought it for looks and hood protection.It's also good quality(had same brand on last 2 trucks w/o problems)and fits PERFECTLY. I also have weather flectors vent visors, excellent quality and fit. About $100 for crew set though. Only prob., they come straight down by mirror, and gets in your visual SLIGHTLY to the pass. mirror
Old Sep 8, 2004 | 07:37 PM
didit26pt2's Avatar
didit26pt2
ITDave, it does have a "Lund" chrome gel pad, about 2 inches wide. At first, I didn't think I wanted it on the smoke bugshield with my black truck. But it actually looks great and blends in with the chrome headlamp fixture.
resq302
Feb 20, 2012 03:03 AM
Ruckus
2004 - 2008 F150
21
Mar 25, 2010 08:01 PM
andrewzx92000
Sep 13, 2009 06:26 PM
bassaway
2004 - 2008 F150
18
Jan 27, 2008 04:44 PM
FordCrusier
Apr 7, 2004 02:50 PM
