Pulling motor tips/tricks
Old Sep 22, 2004 | 07:30 PM
  #46
Chris_ce's Avatar
Chris_ce
Good deal. Thats what i was guessing it was just at to much of an angle.
I have a couple of questions about your truck.
First do you have any tire rubbing?
Second did you cut your front bumper?
Old Sep 22, 2004 | 09:05 PM
  #47
MustangGT221's Avatar
MustangGT221
Didn't cut the bumper, very very slight rubbing if the tire is turned and I hit a hard bump....nothing major. I could remedy the rubbing if I trimmed just a tad off the sheetmetal at the bottom rear of the front wheel wells but it's not enough to bother me or require the procedure.
Old Sep 22, 2004 | 11:56 PM
  #48
MW95F250's Avatar
MW95F250
What are you gonna replace the 302 with?
Are you gonna swap a ZF-5 in?
Old Sep 23, 2004 | 10:32 PM
  #49
MustangGT221
If the 302 is not much good...i'm going to replace it with (most likely) a 406 stroker and yes the ZF would go in if that happened.
Old Sep 24, 2004 | 08:04 PM
  #50
evilbeast's Avatar
evilbeast
Question
is the 406 still a 302 block, or is it a 351 block? the reason i ask is because i have a 408 that im bout to drop in mine in the next week or so, and it is based off of the 351, just curious!
Old Sep 24, 2004 | 09:06 PM
  #51
optikal illushun's Avatar
optikal illushun
i think the 302 is good for about 355ci if that...congrats on getting the engine out. i just did mine and its almost ready to go back in...seems like a commen problem, heh...
Old Sep 24, 2004 | 09:23 PM
  #52
MustangGT221
The 406 is off a 351. A 351 can go up to 427 i believe.
I might actually get a 392ci....which is a 351 with a 3.85" stroke instead of a 4" stroke, still bored .030" over though. I saw a shortblock of it for $2900.
Old Sep 24, 2004 | 09:24 PM
  #53
optikal illushun
ya u can do a 392/3 stroker for cheap...i was thinkin of it before my 300 **** the bed on me...
Old Sep 25, 2004 | 05:51 AM
  #54
MustangGT221
I think that is the first time i've read on this board that a 300 went. lol
Old Sep 25, 2004 | 09:40 PM
  #55
evilbeast's Avatar
evilbeast
yeah, the 351 is good for about 427 reliable, you can get a little more if you dare, but i dont reccomend it, best of luck on the swap, hope ya are happy wit it!
Old Sep 25, 2004 | 10:31 PM
  #56
alabamabuddog's Avatar
alabamabuddog
Any update on your project?
Old Sep 26, 2004 | 03:31 AM
  #57
MustangGT221
Well so far I'm trying to pickout what engine I want to buy and am crunching numbers as to what this is going to cost me and what I can afford.
In a perfect world I'd like a 392ci stroker kit w/ forged parts and the sportsman block ($3400) with AFR heads and roller rockers, but no dice on that. Might get the 392ci stroker with non-forged parts for $2895 or just a regular 351 (all of these are shortblocks) rated for 385hp at $1795. It's an $1100 difference between that reg 351 and the cheaper 392ci...so I'm not sure. Everything in this project seems to be "just a couple hundred more" and a lot in return...but those extra couple hundreds add up real fast. I've already spent $1000 on a MAF conversion w/ 75mm meter, 24# injectors, and a 56mm throttle body. My problem is I am also swapping from 5.0 to a 5.8L block so I have to swap the engine and stuff like the flywheel, clutch, balancer etc etc need to be purchased as well.
Old Sep 26, 2004 | 07:29 AM
  #58
alabamabuddog
Sounds like you need to be junk yard diving for spare parts. I didnt use any in my own but would have if I had choosen to go up to a 351. Where did you get your MAS unit.
Old Sep 26, 2004 | 07:45 AM
  #59
MustangGT221
I knew a guy on the site who was selling it and got it from him. The other stuff was from ebay.
I've gone to 2 junkyards so far...no luck yet.
Old Nov 25, 2004 | 09:32 AM
  #60
MustangGT221
Ok, you guys are long overdue for an update.
I went with a 393 from Coast High performance, it was $2400 with forged pistons, I-beam rods, 3.85 cast crank, ARP rod bolts. I've got a mild cam, hardened pushrods need to be purchased after measurement, FMS 1.72 roller rockers, MSD pro-billet dist, edelbrock intake, GT-40Y heads, HV oil pump, and I think that's about it in describing the engine.
I'm waiting on some gaskets that are suppose to arrive in a few days, once I have those I can assemble the engine to the valvetrain. I need to measure the correct pushrod length, order and recieve those, then install that and put the intake on, and finish the assembly. I've purchased an 89 F-250 with a ZF which will be put into my F-150. The F-150's original M5OD will be put back into the F-250 (so a ZF to M5OD swap on the F-250, and a M5OD to ZF swap on the F-150) so that I could still drive the vehicle (I'll use it as my transportation until my F-150 is done).
My question is this....when I did the work on the F-150, I left the transmission in the truck, and took the engine out. Now that I'm positive the 302 is not going back, I took the M5OD out as well. What I'm wondering, is should I put the 393 and ZF together outside of the truck, then install them together into the vehicle, or should I put the ZF tranny up from underneath the truck, put the motor in, and connect the two units when they're in the vehicle?
